Yb head thickness quick question
Old Jul 1, 2008 | 09:19 PM
lamb chops's Avatar
lamb chops
Default Yb head thickness quick question
My head has just been removed and it seems ive had some piston contact the head measures 138.5 how much can be safley skimmed from these? its 2wd if that makes any odds..
cheers
Old Jul 1, 2008 | 09:21 PM
rapidcossie's Avatar
rapidcossie
depends on comp ratio of pistons
Old Jul 1, 2008 | 09:23 PM
Karl's Avatar
Karl
Norris Motorsport
Do you mean you have had piston to head contact, or valve to piston contact?
lamb chops's Avatar
lamb chops
yeah its being rebuit with new pistons etc Euan so can go lower comp but was just interested as to what people would say is a head which has been to skimmed as it were. what are they standard?
Old Jul 1, 2008 | 09:24 PM
lamb chops's Avatar
lamb chops
valve and piston contact karl, one of the main bearings has collapsed and the rods had lots of movement
Old Jul 1, 2008 | 09:26 PM
Karl's Avatar
Karl
Norris Motorsport
The best solution is to machine the pistons with valve cut outs. With this done it is fine to use a YB head down to 138.0mm thickness. (They are 139.0mm new)
Jasesapphy's Avatar
Jasesapphy
you always get some markings on a piston, i have run 138.4 no probs and people have said they have run 138.3 / 138.2 but only hearsay,
I have run a 138.4 on standard comp and pistons, but cant you just valve cut the pistons
Jasesapphy's Avatar
Jasesapphy
Karl beat me to it
Old Jul 1, 2008 | 09:27 PM
rapidcossie
Take as little of the head as poss but it will still be ok even under Ford's min thickness if its on lower comp pistons.( might even be on standard comps)
Old Jul 1, 2008 | 09:29 PM
lamb chops's Avatar
lamb chops
yeah i can get round it with piston cutout and a low comp piston i guess. thanks chaps. ive not seen the damage yet so hope its not to deep
Old Jul 1, 2008 | 09:31 PM
glancy2081's Avatar
glancy2081
a thought the problem with the skimmed head was that the more its skimmed the less the pressed in part has holding it in ?
Old Jul 1, 2008 | 09:40 PM
PGT's Avatar
PGT
my head is 137.4mm and works fine - the valve seat inserts are on the face though
Old Jul 1, 2008 | 09:42 PM
lamb chops's Avatar
lamb chops
just been told there are some other marks on the head so its going to be pressure tested before any work commences.. can see this getting expensive!!
good to know i have another mm if needed PGT, every mm counts
Old Jul 1, 2008 | 10:08 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
ive ran loads of group A escorts at 137.4mm with no troubles at all.
Old Jul 1, 2008 | 10:13 PM
Karl's Avatar
Karl
Norris Motorsport
Just to add to what has allready been posted, the issue with heads below 138mm is NOT to do with valve seat inserts coming out, but simply that it is impossible to mill an alloy head with a diamond cutter once the seat inserts or valve heads are flush with the head face. (Not to mention the obvious issue that C.R goes up considerably with over 1mm from the head face.)
Old Jul 1, 2008 | 10:44 PM
markk's Avatar
markk
im willing to pay for cylinder heads at or below 138.00mm if anyone is not wanting to use them.
Old Jul 2, 2008 | 03:03 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Cool, my mates car dropped a valve, will need to go to about 100mm to loose the damage .. How much for that?
Old Jul 2, 2008 | 05:15 PM
markk's Avatar
markk
send me a pic, my ally welding is not bad now !
Old Jul 2, 2008 | 05:35 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
I have a brand new 2wd cosworth head yes brand new
Old Jul 2, 2008 | 05:40 PM
bigchez's Avatar
bigchez
How much? I'm guesssing I'll need a mortgage!!
Old Jul 2, 2008 | 07:08 PM
NEIL A's Avatar
NEIL A
Just found these pics in my photobucket of head to piston contact, deep enough pockets so no valve contact but piston top had mushroomed.
Old Jul 3, 2008 | 08:05 AM
lamb chops's Avatar
lamb chops
yeah thats what my number 3 is like Neil, other are ok though. I went round and saw the engine last night and No3 has a full MM movment up and down on the rod. Think i was very lucky this didnt let go while it was running..
Old Jul 3, 2008 | 08:15 AM
rsnissan's Avatar
rsnissan
still have my old head if you need one, needs an ex valve though
Old Jul 3, 2008 | 08:45 AM
NEIL A's Avatar
NEIL A
What comp ratio were you running.
Those pics are of my old engine that i had problems with, was a brand new 200 block with 7.2:1 cosworth pistons
Old Jul 3, 2008 | 08:47 AM
lamb chops's Avatar
lamb chops
not sure Neil as it wasnt built by me last time and i have no reciepts, standard pistons though and stardard bore so presuming standard comp. Also motorsport 200 block
Old Jul 3, 2008 | 08:51 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
i have one that may be of use to you as i probably wont use it. melted a piston so the head is marked. already was low so didnt skim it again, just got another head. might do it and see if its worth anything.
Old Jul 3, 2008 | 08:55 AM
rsnissan's Avatar
rsnissan
do you have to run a remote oil filter etc for this?
Old Jul 3, 2008 | 09:22 AM
lamb chops's Avatar
lamb chops
Not for that one Andy, thats the WRC one your thinking of with all the machining done. This is like a normal 200 without the rear core plug for some extra strengh
Old Jul 3, 2008 | 09:31 AM
NEIL A's Avatar
NEIL A
Yip Mountune WRC block you have to run a remote filter and cooler as there is no place left to fit a filter, also has some extra machining for oil jets and twin oil return
Old Jul 3, 2008 | 10:52 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Same here but it's attached to the block in our 2wd
Cost us Ł990 + VAT direct from Cosworth a couple of years ago
Old Jul 3, 2008 | 12:38 PM
Daxcossie's Avatar
Daxcossie
Chops,
Who is doing your rebuild ?
Old Jul 3, 2008 | 02:27 PM
costina's Avatar
costina
Live long and prosper!!
Stu needs to read this and then he will explain about the squish area!!
Alloy welding a head? I would not do that due heat related problems as the head and the welded area will heat up at different rates..
If the weld dropped out due to expansion of the head it would kill a expensive bottom end..
I've seen 139mm heads which have been tig welded and skimmed and passed off as a unskimmed headu could clearly see around the water jackets that it had been welded!!!!
Paul
Old Jul 3, 2008 | 04:38 PM
lamb chops's Avatar
lamb chops
Originally Posted by Daxcossie
Chops,
It’s being done by a good friend who runs TS Performance, he’s a professional engine builder worked for Pro-Drive and was on the Mcclaren race team for awhile. He knows his stuff, the old girl is in safe hands.
Hes on here sometimes Legend247 i think he is..
Old Jul 3, 2008 | 04:44 PM
frog's Avatar
frog
You mean this !
https://passionford.com/forum/technical-essay-archives/42723-minimum-cossie-head-thickness.html
I believe Karl Norris does this welding work too, when we found out that ours was too thin we considered it as an option as decent heads are few and far between these days. This is until we found a brand new one from cosworth, but not cheap
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
dombanks
Sep 21, 2015 08:38 PM
cbminis
Sep 7, 2015 09:42 AM
hopper350
Sep 4, 2015 12:53 AM
