plenum spacers
Old May 3, 2008 | 09:20 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Default plenum spacers
Ive seen 10 and 14mm spacers, so wots the ideal one to use, pros and cons for either would be appreciated.
Steve
Old May 3, 2008 | 09:31 PM
Miller 3's Avatar
Miller 3
think you need to go 14mm Steve otherwise the injectors sit at the wrong angle and wear the o rings out
Old May 3, 2008 | 09:33 PM
blacky.'s Avatar
blacky.
you need to alter the brackets to mount the injector rail
Old May 4, 2008 | 09:19 AM
JanDK's Avatar
JanDK
I have fitted a 14-15mm spacer.. straight fit!
Old May 6, 2008 | 07:07 PM
blacky.'s Avatar
blacky.
must just be the small ones you need to alter then
Old May 7, 2008 | 06:42 AM
JanDK's Avatar
JanDK
But on the opposit side of the fuelrail mounting lugs. In other words.. the lug measure about 14-15mm I guess
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
