flat battery
Old Apr 2, 2008 | 06:17 PM
georgie1's Avatar
georgie1
Default flat battery
hi people maybe im thick just got the cossy out and yes the battery was flat so charged up it a new battery brought last year plus done the alternator just gone to the car and it just about start up so is the battery shag or have i got a dodge earth do you guys have similar problem any help would be good
Old Apr 3, 2008 | 05:42 AM
georgie1's Avatar
georgie1
Angry
no replys
Old Apr 3, 2008 | 06:49 AM
If a battery is left long enough flat it will kill it, though some are better than others in this respect.
Try a battery of another car, or take yours and get it rapid discharge tested.
Old Apr 3, 2008 | 05:07 PM
georgie1's Avatar
georgie1
cheers m8 at least someone replyed where can i get it discharge tested
Old Apr 4, 2008 | 04:32 PM
georgie1's Avatar
georgie1
any more help would be useful
Old Apr 4, 2008 | 10:58 PM
babscossie's Avatar
babscossie
you need to have a drop test done on the battery and also check what your charge rate is. that will pin point the problem.
Old Apr 5, 2008 | 12:39 AM
mark's Avatar
mark
take the bulb out the boot light
Old Apr 5, 2008 | 12:48 AM
billynocar's Avatar
billynocar
when i worked for motorway tyres long ago
we had a tester
try one of these type places
Old Apr 5, 2008 | 08:12 AM
Wardy257's Avatar
Wardy257
Just check the amps draw with the engine not running. Anything over 0.5 amps will soon drain the battery.
Old Apr 5, 2008 | 10:22 AM
georgie1's Avatar
georgie1
i checked the bulb in boot and it dosent stay on
Old Apr 5, 2008 | 10:27 AM
georgie1's Avatar
georgie1
hi m8 how do i check the amps draw
Old Apr 5, 2008 | 10:51 AM
Miller 3's Avatar
Miller 3
Disconect the live wire and with a meter (set to amps) between the end of the cable and the battery post
Old Apr 5, 2008 | 01:07 PM
georgie1's Avatar
georgie1
can u recommend a good amp meter or where would u get one
Old Apr 5, 2008 | 01:41 PM
Wardy257's Avatar
Wardy257
Maching Mart, Draper brand multimeters are very good.
Old Apr 5, 2008 | 01:49 PM
georgie1's Avatar
georgie1
hi m8 u got link please just look on machine mart and got clarks meters at 50 quid
Old Apr 5, 2008 | 06:24 PM
Miller 3's Avatar
Miller 3
this one will do the job mate http://www.maplin.co.uk/Module.aspx?...001&doy=search
Old Apr 5, 2008 | 09:33 PM
georgie1's Avatar
georgie1
cheers buddy
Old Apr 5, 2008 | 09:47 PM
LHD220Turbo's Avatar
LHD220Turbo
do you have a battery light on when you turn the ignition on?
Old Apr 5, 2008 | 09:56 PM
georgie1's Avatar
georgie1
yes i change the alternator last year but i changed the battery first and drive the car for about three month and was stil getting flat battery so check again and found it was my altenator so this year same battery was flat again as it been away for winter so charged up battery but it go flat if i leave car for a day or two so is the battery dead as wont hold charge
Old Apr 5, 2008 | 09:58 PM
LHD220Turbo
probably have a battery drain somewhere, process of elimnation i'm afraid
Old Apr 5, 2008 | 10:03 PM
georgie1's Avatar
georgie1
i was hoping it was the battery as i let it run flat a few time as altenator wasnt working and maybe has a few dead cell in battery so that why it wont hold charge well i got a new battery and will have to get a mutimeter
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
jay030787
Sep 18, 2015 04:38 PM
