Head work
Old Mar 29, 2008 | 11:59 AM
Rippers's Avatar
Rippers
Monte Geek
Default Head work
In terms of power difference what are the stages in terms of power?
Is a standard inlet is 24mm? good for how much power?
Then you get polished versions.. good for how much power?
Then opened up to 25mm? good for how much power?
Whats next?
This is mine:- measures 25mm top to bottom and is very polished and smooth and my inlet manifold has been matched to it
Old Mar 29, 2008 | 12:20 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i'd like to know the answer to this one too...
Old Mar 29, 2008 | 12:23 PM
R5FORD's Avatar
R5FORD
me 2 as i need to know soon
Old Mar 29, 2008 | 12:59 PM
col cos1's Avatar
col cos1
will let you know once my car is back on the rollers
ive changed my standard head for 26 inlet and 25 exhaust porting
Old Mar 30, 2008 | 01:35 AM
R5FORD's Avatar
R5FORD
noone else knows then
Old Mar 30, 2008 | 03:17 AM
15D's Avatar
15D
Italian convert
Whats next?
IIRC 25mm/25mm ports equate to flow potential for 500-540bhp and 26mm/25mm are good for 600bhp+.
Old Mar 30, 2008 | 10:47 AM
Rippers's Avatar
Rippers
Monte Geek
Old Mar 30, 2008 | 04:44 PM
WD Pro's Avatar
WD Pro
That head looks identical to mine which was done for a 450ish build.
The finish looks rough on photos (more so with flash) but is very smooth to touch. The web between the ports is also very sharp.
Interested in the comments you get as no one seems to want to talk about heads or divuldge specs
Old Mar 30, 2008 | 04:50 PM
dumped's Avatar
dumped
Is it that simple as putting set limits as there is so much else to consider with turbo, cams, manifolds etc? I remember seeing over 420 @ wheels on a standard head and cams before.
3i Jim
Nov 20, 2015 05:12 AM
salsheikh
Alloy wheels and ICE for sale
Aug 20, 2015 12:33 PM
salsheikh
Jul 30, 2015 08:45 PM
