Cossie Compression Test
Old Mar 13, 2008 | 09:03 PM
BigErn's Avatar
BigErn
Default Cossie Compression Test
What should I be seeing when I do a compression test on my Cossie? Its a 4x4 engine. Im unsure what compression ratio is and what I should be seeing.
What reading would I see on an engine that was standard comp, 7.5:1, 7.2:1?
Thanks peoples.
Old Mar 13, 2008 | 09:31 PM
Rs1's Avatar
Rs1
Depending on the state of the engine anything around 160-180psi is quite common, look more so for even readings across all 4 rather than just compression.
Compression and comp. ratio are two different aspects so fiding a correlation between to 2 might not be possible....especially from 7.2/7.5, its not a massive void really. The cams(worn/new?) and cam timing will also have an effect on compression.
Old Mar 13, 2008 | 09:37 PM
BigErn's Avatar
BigErn
I know that comp and comp ratio are different, I was wondering if there was a correlation between the 2.
Im hoping for an interesting read from this or someone who knows for definate, not just from hearsay, to come along and say yes/no and this is why.
Just a nice informative thread for a change, no bitching and fighting would be good.
Old Mar 13, 2008 | 09:58 PM
rst in breaking's Avatar
rst in breaking
most used engines ive done in the past are around 150 on all cylinders
Old Mar 15, 2008 | 07:03 PM
BigErn's Avatar
BigErn
anyone??
Old Mar 15, 2008 | 07:04 PM
BigErn's Avatar
BigErn
And I saw 155psi across all 4 cylinders btw
Old Mar 15, 2008 | 07:46 PM
rst in breaking
shouldnt have a problem with that mate
Old Mar 16, 2008 | 02:53 PM
BigErn's Avatar
BigErn
Cool, I was shittin it when I did the test cos I bought the car with a suspected head gasket failure. But found a split coolant hose and that seemed to sort it. The compression test was for my piece of mind really.
Old Mar 16, 2008 | 02:54 PM
GARETH T's Avatar
GARETH T
i would be happy with that mate!
Old Mar 17, 2008 | 12:42 AM
BigErn's Avatar
BigErn
Sweet, thats what I hoped for. I wasnt sure what to expect.
I have been told elsewher that around 125psi is normal on a cossie???
8.5 bar at cranking speed, plugs out open throttle
Thats what the bible quotes mate for std
compression pressure at starter speed 8.5 bar comp ratio 8:1 (std)
Old Mar 17, 2008 | 01:21 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Too many things effect it, not least of which is the inaccuracy of the gauges, ive seen 20psi difference between 2 gunson gauges I tested out of curiousity.
Also cam timing can have a massive effect on the compression figures you see.
155 on all 4 sounds fine to me, I wouldnt be concerned at all by that.
Old Mar 17, 2008 | 05:46 AM
Red16's Avatar
Red16
just as a comparison Ern my old Clio Williams engine used to compression test at about 180psi and that was 10:1 c/r ... to be honest thats the only car i've ever tested.
Old Mar 17, 2008 | 08:21 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
155 psi on all 4 is ok mate
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
