Another eletrician question....... Found the problem...
Old Jan 30, 2008 | 10:58 PM
MK5RST's Avatar
MK5RST
Default Another eletrician question....... Found the problem...
I have an eletric shower with a pull cord power supply... however i went to switch it on tonight, pulled the cord.... The light on the box on the ceeling came on then i switched on the shower and nothing happened and the light on the box went out.... when i switch the shower back off the light comes back on... seems like every time i switch it on its kinda tripping? any ideas? cheers. pete
Old Jan 30, 2008 | 11:30 PM
BillyCabrio's Avatar
BillyCabrio
Yeah, call a qualified sparkie
Old Jan 30, 2008 | 11:51 PM
MK5RST's Avatar
MK5RST
Old Jan 31, 2008 | 06:14 AM
KSA-Cossie's Avatar
KSA-Cossie
Bad or burnt connection in the pull cord switch m8,as soon as you try to take any load of it it will play up.
Old Jan 31, 2008 | 07:09 AM
richj's Avatar
richj
Fucked pull chord.
Old Jan 31, 2008 | 10:23 AM
MK5RST's Avatar
MK5RST
Cheers lads, ill have a look
Old Jan 31, 2008 | 10:24 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Don't do that whatever you do. You MUST have a qualified Sparkie. OK, it will be 6 weeks before he can come and take a look, but hey, thats life.
Old Jan 31, 2008 | 10:31 AM
MK5RST's Avatar
MK5RST
have you ever heard of the sparkie sex postition? Its awesome! You both stay in all day and no fooker cums
Old Jan 31, 2008 | 10:34 AM
T3ORA's Avatar
T3ORA
have a bath
Old Jan 31, 2008 | 10:35 AM
MK5RST's Avatar
MK5RST
Originally Posted by T3ORA
have a bath
Do you know i hadnt thought of that...
Old Jan 31, 2008 | 10:40 AM
Cowboi's Avatar
Cowboi
chances are it will have a feed straight from teh fuse board and be labled up.
have a check and if it is and you turn it off you should be ok to open it up and have a look.
would advise you check it with some voltage testers first though.
it might just be loose and need tightening up, or burnt out.
either one you capable of fixing really and saving some money.
but i never told ya to do it
Old Jan 31, 2008 | 10:51 AM
MK5RST's Avatar
MK5RST
Im used to playing with eletrics so shouldnt be a problem pal, ill make sure its switched off at the board and they use my eletric screwdriver to test for voltage, failing that ill get the girlfriend to touch it
Old Jan 31, 2008 | 05:57 PM
MK5RST's Avatar
MK5RST
Ive taken the front off the pull cord box on the ceeling to find the neutral output (to shower) wire melted and broken down, the rest of its fine, ive taken the box off the shower and the wires in there are mint too, is it just a case of chopping some off then stripping the end and screwing it back into the connector block? any sparkies came across this before? pete
PS: The mains power is off and ive tested it for any power and its dead now
Old Jan 31, 2008 | 06:05 PM
adduk's Avatar
adduk
most prob have been a loose connection at the back of the switch.showers pull alot of load and if its been arc'n it could quite easily cause that.but to be sure i would advise to get someone in to test it and make sure.bad electrics cause fires and better to be safe than sorry.
Old Jan 31, 2008 | 06:09 PM
MK5RST's Avatar
MK5RST
Hmm, i am a firefighter so no problems there, im gonna have a look in the morning in that case
Old Jan 31, 2008 | 08:36 PM
KSA-Cossie's Avatar
KSA-Cossie
Cut the burnt bits back and if it was me i'd fit a new switch too.
Old Jan 31, 2008 | 08:41 PM
escort greg's Avatar
escort greg
Yep not the first time ive fixed a burnt out pull cord happens a lot because there a ba**ard to do and push back but defiantly change the pull cord 45amp
bobsworth
77
Mar 24, 2016 09:30 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
hopper350
Sep 4, 2015 12:53 AM
