Compression Ratios
Old Jan 28, 2008 | 04:41 PM
drsrst2zvh's Avatar
drsrst2zvh
Default Compression Ratios
I have no idea what they are someone with some insight please spread some light on the subject for me. I.e whats best for 2ltr zvh what they mean etc etc...
Old Jan 28, 2008 | 06:08 PM
GARETH T's Avatar
GARETH T
the compression ratio is the ratio difference of how much the air is compressed from when the piston is at bottom dead center to top dead center (piston at the top of its bore, piston at its bottom)
i cant advice on a actual compression ratio as it depends on so many things!
Old Jan 28, 2008 | 06:35 PM
drsrst2zvh's Avatar
drsrst2zvh
So the more you have the piston machined down the lower the compression ratio will be? what do teh numbers stand for then like 8:5:1???
Old Jan 28, 2008 | 06:50 PM
stevetinks's Avatar
stevetinks
volume ratio for when the piston is at bottom dead center(greatest volume) compared to when the piston is at the top (least volume)
Old Jan 29, 2008 | 08:42 AM
If you machine the piston you will have MORE compression, think carefully and take advice from people who have done this as todays fuels are not that tolerant of high CR's.
On a car that is NOT forced induction you only have the ONE CR to worry about, obviously if it is Forced induction, you need to figure in the ADIABATIC CR as well, as you have TWO CR's.
Old Jan 29, 2008 | 09:33 AM
bud-weis's Avatar
bud-weis
Football Cwazy
It means that the volume of the cylinder at BDC is 8.5 times greater than when it's at TDC.
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
