Central heating experts help needed
Old Dec 5, 2007 | 06:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Central heating experts help needed
Three of the radiators in my house are stone cold the others are roasting,i've tried to bleed them but no air comes out only water.
If i bleed off about a pint of water the radiator starts to heat up at the bottom but once i stop bleeding the water it goes cold again,any tips please ??
Old Dec 5, 2007 | 07:07 PM
Escos Jam's Avatar
Escos Jam
Get Euan on the case mate. He'l sort ya out
Old Dec 5, 2007 | 07:11 PM
KSA-Cossie's Avatar
KSA-Cossie
Mr Begbie are you there.
Old Dec 5, 2007 | 07:12 PM
nilrem's Avatar
nilrem
STOP!... Carry on
are you bleeding the highest radiator? apart form that im unsure...
Old Dec 5, 2007 | 07:18 PM
KSA-Cossie's Avatar
KSA-Cossie
All on one level m8
Old Dec 5, 2007 | 07:21 PM
turbo_3dr_tommy's Avatar
turbo_3dr_tommy
turn the radiators off which are heating up that should push the heat to the cold rads, also sounds like the system needs balancing
Old Dec 5, 2007 | 07:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Whats balancing m8 ?
Old Dec 5, 2007 | 07:34 PM
turbo_3dr_tommy
balancing means to balance the flow to each radiator.
what you need to do is take the cover off the loack shield valve (the oposite valve to the one you can turn) and screw in the valve on each of the radiators which heat up quickly.
Old Dec 5, 2007 | 07:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Cheers for that m8.
Old Dec 5, 2007 | 07:40 PM
rapidcossie's Avatar
rapidcossie
has this just happend Kev?
Old Dec 5, 2007 | 07:42 PM
KSA-Cossie's Avatar
KSA-Cossie
More or less over the last week euan
Old Dec 5, 2007 | 07:48 PM
rapidcossie
What kind of boiler is it mate...
Old Dec 5, 2007 | 07:52 PM
KSA-Cossie's Avatar
KSA-Cossie
Combi , how do i get the plastic head off the thermostat valve at the rad ??
Old Dec 5, 2007 | 07:53 PM
rapidcossie
Dont rush in mate....
Read me the exact model and make from the fron of the boiler
Old Dec 5, 2007 | 08:00 PM
KSA-Cossie's Avatar
KSA-Cossie
Ideal mini c28 m8.
Old Dec 5, 2007 | 08:02 PM
rapidcossie
Whats the presure at?
Old Dec 5, 2007 | 08:04 PM
KSA-Cossie's Avatar
KSA-Cossie
1.5 bar
Old Dec 5, 2007 | 08:09 PM
rapidcossie
everything seems cool then.
turn all the rads off athen turn on each of the problem ones and make sure they heat up
Old Dec 5, 2007 | 08:12 PM
KSA-Cossie's Avatar
KSA-Cossie
Doing that now m8,is it a blockage somewhere ? Weird that when i drained off water the bottom of the rad heated up .
Old Dec 5, 2007 | 08:14 PM
rapidcossie
seems as their is a restriction somewhere mate...
what colour is the water coming out the rads?
Old Dec 5, 2007 | 08:15 PM
KSA-Cossie's Avatar
KSA-Cossie
The one in the bog was black the others were clear.
Old Dec 5, 2007 | 08:18 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Have the non heating up rads have thermostatic rad valves (trv) fitted?, if yes then try to unscrew the trv head only, and push the little pin which is now exposed on the trv body in and out GENTLY, wait a couple of seconds and the pipe leading to the rads may start to heat up. The trv may be stuck and might need some gentle encouragement with a hammer to the the body of the trv to free it!
If not, the system may need balancing?
rapidcossie
black water usually means blockages or the start of problems.
this can be cured by adding chemicals to the system but its not really a job for a DIY'er no disrespect mate.
Best thing to do in short term is let the boiler pump to each of the prob rads only(all others closed) for ten mins to try and clear any partial blockages then open all the rads and report back
Old Dec 5, 2007 | 08:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Originally Posted by Steve the Plumber
Have the non heating up rads have thermostatic rad valves (trv) fitted?, if yes then try to unscrew the trv head only and push the little pin which is now exposed on the trv body in and out GENTLY, wait a couple of seconds and the pipe leading to the rads may start to heat up.
If not balance the system may need balancing?
How does the plastic head come off ?
KSA-Cossie's Avatar
KSA-Cossie
Will do euan thats a beer im owe ya m8.
Old Dec 5, 2007 | 08:22 PM
rapidcossie
Unlikely that 3 TRVS have jammed at the exact same time...
We need to know what kind of rad valves before I can say how to take them off.
Take a pic?
Systems dont tend to just need balenced after years of working perfectly unless there is somekind of restriction forming..
Old Dec 5, 2007 | 08:26 PM
Steve the Plumber
If the water is that black and sludgie out of the system, just adding a chemical into the system is a waste of time and effort, you'd be better off getting someone in to power flush the boiler and system!
Old Dec 5, 2007 | 08:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Valves are westherm if that helps at all.
Old Dec 5, 2007 | 08:29 PM
rapidcossie
tell him the price and wait for him to faint
Old Dec 5, 2007 | 08:30 PM
Steve the Plumber
Just below the plastic trv head is normaly a chrome lock nut type thing, use some adjustable grips to undo.
KSA-Cossie's Avatar
KSA-Cossie
I heard its hundreds .
Old Dec 5, 2007 | 08:32 PM
rapidcossie
Scot gas charge 600 ish mate
Dont worry too much just now tho...
Any of your mates plumbers asit easier to get them in to try the basics frist
Steve the Plumber
Anything between £250-£500, Ker-ching
Old Dec 5, 2007 | 08:44 PM
KSA-Cossie's Avatar
KSA-Cossie
Unlikely but they were all stuck but now freed off what could i use to lube them ?
Thanks very much to you and steve euan.
Old Dec 5, 2007 | 08:51 PM
Steve the Plumber
Well done, you should be warm and toasty now!
Theres no need to lube them because they stick internally, turn them up and down now again, or give them a good whack if they stick again! LOL
Old Dec 5, 2007 | 08:55 PM
KSA-Cossie's Avatar
KSA-Cossie
Will do m8 thanks again.
Old Dec 5, 2007 | 09:26 PM
rapidcossie
I was wrong
you could just take the heads off for a while then the valves acant shut and jam
Old Dec 5, 2007 | 11:16 PM
rigwrecker's Avatar
rigwrecker
if ur brave u can pull the pin outwith a pair off pliers put some grease on the pin and push it back in but have an old sheet and some kitchen roll ready once back in move out and in a few times to free up the valve
JPA
Nov 8, 2015 12:26 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
