compression struts
Old Oct 23, 2007 | 06:40 PM
cosworthbg's Avatar
cosworthbg
Default compression struts
Hi,what's your opinions of compression struts? Will the car's handling be better when anti roll bar is removed and a set of theese is fitted?
Old Oct 23, 2007 | 06:43 PM
JHS's Avatar
JHS
I asked this question a while ago, turned into a 4 page discussion Have a search
Old Oct 23, 2007 | 07:15 PM
ECOS95's Avatar
ECOS95
Think the answer was no if its a road car.
Old Oct 23, 2007 | 07:22 PM
rapidcossie's Avatar
rapidcossie
I have tested both and would say yes.
There will be a compression strut kit available from AVA over the next few months that will be a MASSIVE improvement on what is currently available.
Old Oct 23, 2007 | 07:35 PM
cosworthbg's Avatar
cosworthbg
I found the thread JHS was talking about and as far as I understand from the discussion, the compression struts are good upgrade only used with anti roll bar mounted in the front under the cross member.So the question that occurs on my mind is where can I get such arb to fit with comp struts
Old Oct 23, 2007 | 07:37 PM
cosworthbg's Avatar
cosworthbg
ooops,double post
Old Oct 23, 2007 | 07:50 PM
Mr RS500's Avatar
Mr RS500
Comp struts arnt good for road use , and i dont care who tells you anything else ,
I have had cars fitted with them and removed and went back to ARB and found the car much better to drive as you arnt relying on the suspension ( ie shockers and sprinds )alone
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
