Ignition module wiring
Old Oct 9, 2007 | 03:02 PM
Cosworth Bassie's Avatar
Cosworth Bassie
Default Ignition module wiring
Why do the Cosworth ignition module (BKL3B) have 2 wires to the ECU to pin 24 & 25 ??
I'm busy with wiring a stand alone ECU, but can't figure out why there are 2 wires from ECU to the ignition module, because normally theres only one trigger wiring from ECU to ignition module.
Who can tell me , why this is, and what the difference is between these two wires which go to pin 24 & 25 from ECU?
Regards,
Bas
Old Oct 9, 2007 | 03:27 PM
jon@work's Avatar
jon@work
this any good to you ?
http://www.motec.com.au/drawings/m11.pdf
Old Oct 9, 2007 | 03:43 PM
white4x4cos's Avatar
white4x4cos
pin 24 ign. ground
pin 25 ing. trigger
Don't know why it have it's own ground???
Old Oct 9, 2007 | 05:08 PM
Cosworth Bassie
@ Jon
Thanks, but that's another ignition module as the std Cosworth one.
I'm going to use the std module, and that one is having 2 wires connected to the ECU. Or am i missing something in that diegram you were giving?
@ White 4x4 cos
Already found this indeed:
Webber/Marelli’s IAW045 and IAW048 ECU connector wiring
1 - Ground
2 - O2 sensor (IAW048 cat model)
3 - Crankshaft RPM sensor (-)
4 - Crankshaft RPM sensor (+)
5 - Camshaft Phase sensor (-)
6 - Knock sensor (IAW048) (-)
7 - Cannister (IAW048)
8 - Diagnostic
9 - n.c.
10 - Main relay (-)
11 - Gnd ref. sensors (-)
12 - ECU warning light (-)
13 - Service Connector (-)
14 - Service Connector (-)
15 - MAP sensor signal (0-5v)
16 - Wastegate control solenoid (-)
17 - Throttle position sensor (0-5v)
18 - Injector 4 (-)
19 - Engine ground
20 - 12V (main relay)
21 - Air conditioner signal
22 - Knock sensor (IAW048) (+)
23 - Camshaft Phase sensor (+)
24 - Ignition module (amplifier) out (-)
25 - Ignition module (amplifier) out (+)
26 - n.c.
27 - Diagnostic
28 - Fuel pump relay (-)
29 - Water temperature sensor (0-5v)
30 - 5v sensors (+)
31 - Intake air temperature sensor (0-5v)
32 - Injector 2 (-)
33 - Injector 3 (-)
34 - Idle valve solenoid (-)
35 - Injector 1 (-)
But this still doesn't make sense to me, because the module have it's own ground ( first to mae cooler and from there to engine ground), so why does it have 2 wires to the ecu???
And i assume i need them both to make it work with a stand alone system isn't it?
Somebody?
Regards,
Bas
Old Oct 9, 2007 | 08:11 PM
Cosworth Bassie
Up
Old Oct 9, 2007 | 08:17 PM
ECU Monitor Enthusiast
Ok, it has its own ground because the cossie normal ecu ground can vary
due to injector peak currents and wiring voltage drops in these conditions.
If there wasnt a seperate ground, the coil would missfire as the ground
of the ecu moves around 0.5volts during various conditions due to the trigger
signal being only a 5 volt (TTL) signal as is very suseptible to electrical
noise and disturbance.
Hope that explains things.
Simon
Old Oct 9, 2007 | 08:29 PM
Cosworth Bassie
Simon
So, the wire to the ECU (pin 24) is nothing more then an extra ground but via the ECU?
What to do with that wire if you are going to use a stand alone system, so remove the std ecu? Just connect to engine ground at the car?
Thanks!
Regards,
Bas
Old Oct 9, 2007 | 08:37 PM
That ground may or may not be needed depending on the ecu used.
Old Oct 9, 2007 | 08:54 PM
Cosworth Bassie
Ok, will sort that out!
Thank you mate
Regards,
Bas
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
