T3?
Old Aug 27, 2007 | 12:48 PM
RS LOZWORTH's Avatar
RS LOZWORTH
Default T3?
Whats the max boost you can run a T3 at on a 2wd?
Old Aug 27, 2007 | 12:55 PM
mechanic28's Avatar
mechanic28
would say realible around 18psi
Old Aug 27, 2007 | 12:56 PM
RS LOZWORTH
so its gonna be no good for stage 3?
Old Aug 27, 2007 | 12:58 PM
rog's Avatar
rog
U can run it at stage 3 level, it just won't last as long as it should, ran mine for 4 years before it went pop. Suppose it depends on the chip though really, do u know what it's set up to run? For proper stage 3 u really should be looking at a T34 tho minimum IMO.
Old Aug 27, 2007 | 01:03 PM
RS LOZWORTH
im currently running stage 1 at 261bhp but im thinking bout going to stage 3 but cant afford everything at once so i was going to get all the injectors, map sensor, chip etc then get a turbo when i have more money, or is it best to wait till i can afford both...
Old Aug 27, 2007 | 01:06 PM
mechanic28's Avatar
mechanic28
u could do it that way but if u get a T34 later u will have to change your chip,plus with a T3 u only really going to get around 300bhp mark where with a T34 around 330-340 mark
Old Aug 27, 2007 | 01:11 PM
rog's Avatar
rog
Ditto
depends, u could run it on a chip for a T34 and upgrade the turbo later, just won't be as powerful with the T3. But that depends if you want to just go for it right away or do it"properly" and get all the bits together. If you see what i mean. Basically running a T3 and stage 3 chip for a T34 won't do any harm.
Old Aug 27, 2007 | 01:12 PM
RS LOZWORTH
so let me get this right if i want 330-340bhp i need t34, chip, 3 bar map sensor, dark green injectors, i all ready have RS500 intercooler, do i need anything else? breather maybe?
Staffi's Avatar
Staffi
Try the NMS gunship conversion, i think you'll be VERY impressed.......
Old Aug 27, 2007 | 01:14 PM
RS LOZWORTH
have u got a link so i can read about that?
Old Aug 27, 2007 | 01:15 PM
rog's Avatar
rog
Ah i forgot about that, i wouldn't mind trying it myself!
Old Aug 27, 2007 | 01:18 PM
mechanic28's Avatar
mechanic28
yes defo breather kit! take it u got the usual stainless steel induction kit etc???yeh nms stage 1 gunship are suppose to be very good
Staffi's Avatar
Staffi
I think if you type it inot search you'll find info on it...
This conversion is awesome, the perfomance figures Tiff got from his was fantastic, 0-100 in just 12 secs, tha's not bad when you think an M3 is doing it in similar times..
Old Aug 27, 2007 | 01:19 PM
mechanic28's Avatar
mechanic28
link for his site
http://www.norrismotorsport.co.uk/
Old Aug 27, 2007 | 01:21 PM
rog's Avatar
rog
Old Aug 27, 2007 | 01:23 PM
Staffi's Avatar
Staffi
PM Tiff of here, or BoXXer,Both had this conversion..
Old Aug 27, 2007 | 01:24 PM
RS LOZWORTH
cool just read bout that stage 1 gunship conversion, dosent say anything about price thow but cant imagine it wud b mega bucks!
mechanic28's Avatar
mechanic28
think it around Ł350 for live map??could be wrong tho!!!!
Old Aug 27, 2007 | 01:25 PM
Staffi's Avatar
Staffi
It's not very costly no, but it holds it's on with many so called stage 3 cars....
Old Aug 27, 2007 | 01:27 PM
mechanic28's Avatar
mechanic28
apart from on the motorway although its ment to be top conversion would want to give it large for long periods as 24 psi spike on yellows is askin for truoble over a long period!well imo anyways!not that anyone listens to me
Old Aug 27, 2007 | 01:30 PM
Staffi's Avatar
Staffi
But you can only do 70 on motorways... well, in mine there's usually a 1 on front of that..
Arr, the joys of 440 bhp...
Old Aug 27, 2007 | 01:31 PM
RS LOZWORTH
i only do like 2000 miles a year in it anyway! its only a toy
Old Aug 27, 2007 | 01:32 PM
Staffi's Avatar
Staffi
Well i'd give it a Gunship for sure...
Old Aug 27, 2007 | 01:33 PM
RS LOZWORTH
Smit's Avatar
Smit
The 60ft Launch King
I've had both a stage 3 T3 conversion and a T34 one
T3 one boost up a lot quicker and the repsonce is very quick.. Downside is it runs out of puff when your giving it some bananas
T34 is more laggy but more power up the revs..
Both nice conversions.. Running a T3 @ 1.3Bar (20psi) would make a wicked little driver
Old Aug 27, 2007 | 01:34 PM
mechanic28's Avatar
mechanic28
Old Aug 27, 2007 | 01:59 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Well I was considering the gunship conversion a while back on a stage 3dr I had. I gave NMS a ring and he explained it to me like this.....
The yellows/blues in a std cossies can deliver enough of a pulse of fuel low down in the revs to cope with a massive spike (and then some) its only when you want big boost and high rpm that the injectors cannot flow enough as theyre limited on pulse time/flow rate due to high rpm....
Basically saying the NMS gunship conversion uses lots of boost low down in the revs where the injectors can cope compfortably and then slopes off the higher the revs go..keeping everything safe and within the limits of std injectors.
I've only heard good things about this conversion and for the price its got to be a no brainer if your not after massive motorway speeds or top end power.
Dan
Old Aug 27, 2007 | 02:02 PM
RS500/364's Avatar
RS500/364
When my saff T3 was done 360 bearing i asked him and said was good for 28 psi
so i will run only 24PSI
Old Aug 27, 2007 | 02:07 PM
Staffi's Avatar
Staffi
I think he just spikes the boost at something like 28psi then drops it right off for safety... the injectors wouldn't cope else.........
Old Aug 27, 2007 | 02:37 PM
RS500/364's Avatar
RS500/364
greens will near the limet
