Spark plug colour.
Old Sep 29, 2004 | 11:25 AM
ImaRacing 700's Avatar
ImaRacing 700
Default Spark plug colour.
Right..i been out ragging the car yesterday ...Took spark plugs out today.....
3 were lovely grey/brown perfect
No 2 (on plug lead) was looking more whitish now i did notice that the gap was a tiny bit bigger than the rest.
So:-
Can gap if open slightly more cause a colour change?
Could that plug be failing at all?
Is that no 2 cylinder prone to run more lean than the rest?I did have a seal leak on that injector in the inlet manifold before...but i put a new seal and that seemed to cure it....(as it caused onboost misfire)..any other reasons????Fooked injector..any tests i can do?
Old Sep 29, 2004 | 11:39 AM
cossymad's Avatar
cossymad
red coating- additive in fuel
black fuel fouled- wrong heat range or too rich
oil/ash fouled white ash- oil seal leaking
black carbon fouled- too much low speed driving or heat range wrong
other than that don't worry
Old Sep 29, 2004 | 12:17 PM
M Brian's Avatar
M Brian
i was wondering this...
mine come out pretty white electrode, with black base and around the thread area.
Old Sep 29, 2004 | 12:49 PM
Spiky's Avatar
Spiky
thought no3 piston was the iffy one
Old Sep 29, 2004 | 01:05 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Phil,
If this is the cylinder that had the air leak, then it obviously still has one...
If it is nothing to worry about, then it will be the same colour as the others after you have matched the gap. If it isn't, then it is either getting more air or less fuel than the others.
Old Sep 29, 2004 | 03:17 PM
ImaRacing 700
Sorted
The std injector next to the leaky grey was er leaking so new seal all sorted..idles properly cold now too ....Hope i didnt do any damage on No 2 But i guess if its now fixed and its still on 4 no probs it survived,plus the fact there was no misfires and that plug aint what i'd call really lean..just leaner than the others..LOL ...i looked at the piston down the plug hole and it looked the same as all the others..fine...although cant see that much..lol.
Old Sep 29, 2004 | 04:37 PM
M Brian's Avatar
M Brian
I hope you examined it properly!! and used a torch!!
Old Sep 29, 2004 | 04:57 PM
Mike Rainbird
Caraholic
Good job you actually listened to me for once .
Old Sep 29, 2004 | 05:10 PM
matts1's Avatar
matts1
Red colour - Additive in fuel, sorry if this is a daft question but what would be the additive?
ImaRacing 700
Red diesel
Old Sep 29, 2004 | 05:15 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
red paint
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
