running lean???
Old Jul 30, 2007 | 11:15 AM
R5FORD's Avatar
R5FORD
Default running lean???
hi guys..
well i got stage 3 closed loop system, 4x4 tps, greens, t34.48, 3 bar sensor, and all the kit to run stage 3, i took it for a dyno today and ony punched out 310 bhp as the tester didnt want to run it further as the engine was getting dangeroulsy lean at around 4500rpm..before 4500rpm it was running a little rich but then had a massive lean curve..
does anybody know why this could be happaning and how to resolve it?
cheers aaron
Old Jul 30, 2007 | 11:19 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Can you post AFR's at a few different points so we can see what his opinion of lean was in the first place?
Who's chip is it?
Old Jul 30, 2007 | 11:23 AM
R5FORD's Avatar
R5FORD
its msd chip mate.. got closed loop..yhep il post the graphs up now..
Old Jul 30, 2007 | 11:26 AM
AlexF's Avatar
AlexF
When was it setup?
Old Jul 30, 2007 | 11:30 AM
R5FORD's Avatar
R5FORD
today mate
Old Jul 30, 2007 | 11:31 AM
R5FORD's Avatar
R5FORD
heres the printouts the guy gave me.. if you pay attention to the lambda 1 section..it shws it leaning out at around 4500rpm..
Old Jul 30, 2007 | 11:34 AM
Stu @ M Developments's Avatar
PassionFords Creator
Fuel Filter
Fuel regulator rising rate
Fuel Lines
Fuel pump
Map Sensor (Unlikely due to leaning out on graph looking like a linear flow failure meaning the pressure is falling off)
Old Jul 30, 2007 | 11:38 AM
R5FORD's Avatar
R5FORD
Originally Posted by Stu @ M Developments
Fuel Filter
Fuel Lines
Fuel pump
its got a new fuel pump so could it be the filter or the fuel lines?
its got a new 3 bar..
JjCoDeX75's Avatar
JjCoDeX75
My fuelling issues mainly related to a dodgy Fuel Reg. Has it been changed?
JJ
Old Jul 30, 2007 | 11:40 AM
Fuel Filter
Fuel Lines
Fuel pump
It could be anything that will not allow 350bhp worth of fuel to flow from the fuel tank, through the pump, through teh filter, through the lines and up to teh fuel rail.
It also must do so at 5bar, so the regulator is also a distinct possibility. Have you got a picture to hand of your engine bay?
Do you know what your fuel pressure is set to?
Old Jul 30, 2007 | 11:42 AM
R5FORD's Avatar
R5FORD
standard pressure mate..il get a pic of the bay now and post it up
Old Jul 30, 2007 | 11:46 AM
Chip's Avatar
Chip
"Fuel pump" includes the wiring to the pump as well of course!
Old Jul 30, 2007 | 11:50 AM
R5FORD's Avatar
R5FORD
well only put a new pump on..havent changed the wiring yet..so isit a good idea to change the wiring?
the car is a 2wd saph regard what it says on the dyno sheet
also it has new greens,..new 3 bar..new fuel pres reg..and new fuel pump
Old Jul 30, 2007 | 11:51 AM
Chip's Avatar
Chip
Yes, stick it on a relay.
Old Jul 30, 2007 | 11:54 AM
JjCoDeX75's Avatar
JjCoDeX75
As above - put new chunky 12v cable direct from battery to rear (not forgetting fuse by battery), then buy new relay, and use existing supply wire as signal wire.
JJ
R5FORD's Avatar
R5FORD
ok so eplace the fuel pump wiring? on average how long would this take?and what else? as i need the car to be done soonish..
Old Jul 30, 2007 | 11:55 AM
JjCoDeX75's Avatar
JjCoDeX75
Piece of piss mate - takes as long as it takes to run the wire to the rear. Not a hard job - mine took hour max
JJ
Old Jul 30, 2007 | 11:57 AM
R5FORD's Avatar
R5FORD
so basically run a 12v wire from the battrey? or the existing relay to the rear and just conect it into the original wiring at the fuel pump?
Old Jul 30, 2007 | 11:59 AM
R5FORD's Avatar
R5FORD
heres pics of the engine bay stu..
Old Jul 30, 2007 | 12:06 PM
None of the normal issues seems to be in existence there, although your "New" Fuel reg having the tamperproof cover missing is a tad concerning...
Does it drive and perform properly off boost?
Old Jul 30, 2007 | 12:10 PM
R5FORD's Avatar
R5FORD
yh it drives fine..comes on boost strong and follows through..
the tester tried turning up the fuel pressure then he turned it back down when realising it didnt do anything..
so whas the best thing to do from now then?
Old Jul 30, 2007 | 12:11 PM
R5FORD's Avatar
R5FORD
and yes drives perfect off boost aswel
Chip's Avatar
Chip
And he didnt mention it had a flow issue?
Proper cunt, lol
Old Jul 30, 2007 | 12:15 PM
R5FORD's Avatar
R5FORD
Proper cunt, lol
lol he stopped the test as it was running to lean..he got upto 310 at 21psi and he didnt want to up the boost more due to it running lean etc.. he didnt know why it was running lean..
dont forget im in australia these cars are rarer then ferrar f40's out here lol
Old Jul 30, 2007 | 12:21 PM
Chip's Avatar
Chip
Ah, well fair play on the rarity, but TBH same applies to any car if you up the fuel pressure and dont get more fuel!
Old Jul 30, 2007 | 12:22 PM
gingeRS's Avatar
gingeRS
i'm sure if you flew stu out, put him in a 5 star hotel for a few days
he'd tune it for you
as for the previous fuel reg comment, i wouldnt be letting that guy anywhere near the car
Old Jul 30, 2007 | 12:24 PM
R5FORD's Avatar
R5FORD
lol..stu could stay at my luxury home lol..
forget the hotel the house is better lol
dm cars becoming a pain in the ass
Old Jul 30, 2007 | 12:29 PM
gingeRS's Avatar
gingeRS
dont lose faith....they are just the teething troubles of cosworth ownership
you can be happy that you probably own one of the rarest cars in the whole of AUS
Old Jul 30, 2007 | 12:31 PM
R5FORD's Avatar
R5FORD
yh the looks i get makes it all worth wile..
just the cars bein off roas for ages and when i get it done i got this minor problem..
which hopefully if i put a new filter in.. and new wires to the pump should go
Old Jul 30, 2007 | 02:45 PM
JjCoDeX75's Avatar
JjCoDeX75
Easiest place to put the relay is at the rear of the car.
Wire from Battery to new Relay to supply IN of Relay. Put in-line fuse in right by Battery so if the wire chafes, it doesnt cause a fire. Will need to be sensibly sized fuse (to match original requirements of the pump - I think 30Amps will Do it).
There are two wires that connect to the fuel pump - plus and minus. Minus is earth (IIRC). Check that you have good continuity to earth. If not - replace this wire with new strap to good metalwork. Also earthy Relay.
Cut off wire from + terminal. This is now your signal wire. Put this onto the Signal terminal of the relay.
Finally put a good quality cable from the Output of the Relay to the pump + position.
This way, whilst the signal of the original plus cable is not necessarily good enough to power the pump properly, it will be good enough to tell the relay to do so.
Job done!
Then switch car on, and test voltage across the fuel pump with a Volt meter.
JJ
Buy New relay. Put relay in boot area somewhere safe. Many attach to the
Old Jul 30, 2007 | 02:57 PM
AlexF's Avatar
AlexF
Graceland did a great write up on rewiring to the fuel pump...
have a search!
Alex
Old Jul 30, 2007 | 03:14 PM
Graceland's Avatar
Graceland
Team HOTHOT!
have a search!
Alex
https://passionford.com/forum/viewtopic.php?t=174562
Old Jul 30, 2007 | 04:03 PM
foreigneRS's Avatar
foreigneRS
Testing the future
clearly the tuner was not successful in raising the fuel pressure, even though he fiddled with the regulator. if he had been, more pressure difference across injector = more fuel flow = less leaning out
that infers that either the fuel supply system is not up to the job, or that the fuel pressure reg. does not work in keeping the fuel pressure a fixed amount above the pressure the other side of the injector
as said, wiring should be first easy job along with fuel filter. those should be done on a car of that age anyway.
Old Aug 10, 2007 | 08:08 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Interestic item this is!
Not want to hyjack this topic but maybe you guys can also give me some info about my graphic of my engine running way too lean on a rolling road session from start all up the rev range?
Here's the printout:
Old Aug 10, 2007 | 08:13 PM
Can you two guys not get access to some live data from the management and show us what the injectors are doing under load?
Old Aug 10, 2007 | 08:36 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Sorry Stu, not having the equipment to get this information for you.
But in my case its all over the range.. Thanks for joining in with you knowledge
Cheers Wim
Old Aug 10, 2007 | 10:15 PM
Cheers Wim
You should club together and buy it.
You could ship teh laptop to each other by DHL
Old Aug 10, 2007 | 10:32 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Thanks for this bright idea..
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
