engine builder help please
Old Jun 20, 2007 | 02:22 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default engine builder help please
think ive been stupid!
ive bought a zetec bare block but hasnt got the main caps, my mate said that the block is useless without them as there matched to that block is it true? can i get another set of caps and get a pro to check them?
Old Jun 20, 2007 | 02:24 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
unless you get the caps and have it line bored, it'll make a good coffee table lol
Old Jun 20, 2007 | 02:27 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As Dan says, needs a line bore now basically, which is bastard expensive compared to just going and sorting yourself a block thats complete.
you may get away with it if you try a set of mains off another engine, but its pretty unlikely it will be correct.
You can check it with a dial dauge.
Old Jun 20, 2007 | 02:40 PM
Roosie's Avatar
Roosie
i have a spare set of ends of an exact same engine but you wouldnt be able to check with eye.
why are they exact to that engine? whats the difference between each
Old Jun 20, 2007 | 02:42 PM
AlexF's Avatar
AlexF
The caps and block are machined to make 5 inline holes which are perfectly inline with each other...
The holes are therefore not in the same place engine to engine.
Alex
Fudgey's Avatar
Fudgey
Baby Cheesus
the main caps are bolted to the new block, then they are then line bored.
over time the bore tool wears so you get differences in tolerances hence different sizes in the bore
and no, you cant check by eye
Old Jun 20, 2007 | 02:43 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
and what alex said
Old Jun 20, 2007 | 02:46 PM
xr4x4rs's Avatar
xr4x4rs
well i never knew that
thought they would be the same
what exactly is line boring then
at a guess is it where the machine just machines where the crank would sit?
to get true reading on all bearing surfaces?
Old Jun 20, 2007 | 02:47 PM
Roosie's Avatar
Roosie
oh well looks like a waste if Ł50
Old Jun 20, 2007 | 02:53 PM
Chip's Avatar
Chip
Line bore is essentially drilling a hole very accurately.
Its done on cam caps, mains caps, conrod caps.
The two parts are placed together, then the hole bored in them.
No two end up EXACTLY the same, so you cant interchange on any of them.
Old Jun 20, 2007 | 02:54 PM
Roosie's Avatar
Roosie
has anyone ever got away with using different ones?
Old Jun 20, 2007 | 02:56 PM
Chip's Avatar
Chip
Yes, after paying a couple of hundred quid to have them capped and rebored.
Old Jun 20, 2007 | 02:58 PM
Roosie's Avatar
Roosie
i mean without getting them done
Old Jun 20, 2007 | 03:00 PM
Chip's Avatar
Chip
You could try if its just on an old shitter, but the bearings wont see the right amount of crush so its almost certainly a waste of time.
Old Jun 20, 2007 | 03:11 PM
Roosie's Avatar
Roosie
it is a bit of a shitter yes
Old Jun 20, 2007 | 03:13 PM
Chip's Avatar
Chip
worth a try then I guess, but personally I would at least dial gauge them first just to see if its even vaguely like to work
Old Jun 20, 2007 | 03:18 PM
AlexF's Avatar
AlexF
Don't even bother !
It will lock up solid as soon as you tighten the main caps down... and if it doesnt the clearences will be so far out you might not get oil pressure to the big ends LOL!
Alex
Old Jun 20, 2007 | 03:21 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
just stick it on ebay mate
you but complete engines for a oner
Chip's Avatar
Chip
Originally Posted by AlexF
Don't even bother !
Alex
I agree, but he seems determined to find out the hard way and wreck a set of bearings in the process, lol
Old Jun 20, 2007 | 03:22 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
this has just happened to someone on the GTR board with the cam caps, same problem, ie your fucked
AlexF's Avatar
AlexF
Its less money than you spend on a good night out - don't stress
Old Jun 20, 2007 | 03:42 PM
Roosie's Avatar
Roosie
suppose least its got all the zvh parts i need a set of calibra turbo pistons must be worth a bit
Old Jun 20, 2007 | 03:44 PM
Chip's Avatar
Chip
There have been a few sets of secondhand calibra turbo pistons on migweb.co.uk advertised recently
Old Jun 20, 2007 | 03:45 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
have you tried asking the person you bought the engine off if they still have the caps?
Old Jun 20, 2007 | 03:47 PM
Chip's Avatar
Chip
Or why they have sold you sometthing more or less totally useless?
Old Jun 20, 2007 | 04:19 PM
Roosie's Avatar
Roosie
sorry i ment th eengine come with calibra pistons so at least i can recoupe some costs
Old Jun 20, 2007 | 04:41 PM
Chip's Avatar
Chip
well they are worth 50 quid easy, ideal!
Old Jun 22, 2007 | 09:28 AM
Roosie's Avatar
Roosie
bit of luck the bloke i got the engine from just text me saying there is 5 main caps hes just found?
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
