Stack Dash Rev Gauge
Old May 20, 2007 | 11:46 AM
Jasesapphy's Avatar
Jasesapphy
Default Stack Dash Rev Gauge
Wired in Stack all good except REVS.
does not read anything, i am on a P8 wasted spark, not a Stu conversion, enabled in the software Chip.
Anybody else had this issue with stack rev gauge and wasted
Any ideas
Oh the sec is registering revs to let you know abiet 1/2 reading as its wasted
Old May 20, 2007 | 05:17 PM
trevCOSS's Avatar
trevCOSS
you could just come off one of the ign amps for your signal?
Old May 20, 2007 | 05:21 PM
Rick's Avatar
Rick
seems like its not getting anything from the ECU tach output?
As said, connect it to one of the coil pack-ve's - thats where mine is. You then have to set it to 2 cylinder which is 4 cylinder wasted spark.
Old May 20, 2007 | 08:28 PM
Jasesapphy's Avatar
Jasesapphy
Rick i set it 2, will have to try going direct to ignition amp, when i connected the wire the engine revs increase
Does anyone know what pin out it is, if not i will call Ryan, think it may be a stack fault as its a brand new loom
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Fordmad!
Sep 29, 2015 07:03 PM
Mc5506
Sep 29, 2015 09:06 AM
IainRS1700T
Sep 25, 2015 06:44 AM
