Rename Dos command
Old Sep 15, 2004 | 02:25 PM
JohnnyB's Avatar
JohnnyB
Default Rename Dos command
Can I rename a file in a Batch file to add a unique identifer on it
The orginal file Cricket_1.jpg Add either a % or a _ then a number upto what ever
Thanks lads
Old Sep 15, 2004 | 02:27 PM
JohnnyB's Avatar
JohnnyB
I know you can use *1* but will at one to all the names not sequeal numbers
Old Sep 15, 2004 | 02:31 PM
Jim Galbally's Avatar
Jim Galbally
you cannot automatically define the identifier (not easily anyway!)
you could use %1 tho
so say batch file is called johnny.bat
you'd say
c:\>johnny.bat 23
and your file would say:
IF %1 = "" ECHO TYPE SOMETHING YOU TWAT
REN CRICKET_1.JPG *%1.*
Old Sep 15, 2004 | 02:32 PM
Jim Galbally
to do sequential numbers you'd need NT scripting ideally.
you can do it in batch but you have to set upa control file and have the batch file read+update the control file... its properly complex and a right pain in the arse...
i struggled enough to add dates to filenames, and sequential numbers are even worse!!!!
do a search for batch programming in google, there are some really good websites with examples that helped me a lot... might find an easier method than the one i know of
Old Sep 15, 2004 | 02:35 PM
Jim Galbally
here's a thought... if its a batch file youre only ever gonna run once (ie you dont need it to remember which number it was on then run it again and it remembers) its a peice of piss... you just use the SET command to define a variable, then SET variable = variable +1 and keep using that variable in the file and call it with %variablename
example... type SET at the command prompt and you can see all the pre-defined variables like PATH and stuff...
Old Sep 15, 2004 | 02:41 PM
JohnnyB's Avatar
JohnnyB
cheers Jim bob
If this did the time it would be good.
ren C:\DATA.txt DATA%dd%-%mm%-%yyyy%.txt
We have PA pictures comming comming in Say in the morning called cricket_1.jpg
Then in the afternoon different pictures come in with the same name and over right the pictures in the fooking database
say if a put the time in it may help
Old Sep 15, 2004 | 02:43 PM
JohnnyB's Avatar
JohnnyB
Just read your last post Jim That may work
Old Sep 15, 2004 | 02:52 PM
Jim Galbally
johnny, does that %dd% %mm% %yy% thng work in 2k?
if so im gonna feel mighty silly... the program i had to do it was a BIT more complicated than that but it was what i was using on win95
Old Sep 15, 2004 | 02:54 PM
Jim Galbally
Code:
REM @echo off
echo.|date|find "Current" >cuXXent.bat
echo set date=%%5> current.bat
echo e 116 "-" > script
echo e 119 "-" >> script
echo w >> script
echo q >> script
type script | debug cu##ent.bat > nul
del script > nul
call cuXXent.bat
rem del cu??ent.bat >nul
Old Sep 15, 2004 | 02:56 PM
JohnnyB's Avatar
JohnnyB
aye it does work in 2k
I did this in a .bat file
set pa=pa+1
does not work
I think work in progress
tar
Old Sep 15, 2004 | 02:58 PM
Jim Galbally
aye that wont work
1st set pa to 1
then set a loop startpoint
then do an if exist to make sure theres a file there to rename (if not exist goto end)
then rename your file
then set pa to pa+1
then loop back to before the if exist
then just bung a :end in there
Old Sep 15, 2004 | 02:59 PM
Jim Galbally
you need the loop to run once for each individual file... you cant rename *.jpg to *%pa.jpg as itll try n call em all the same name (what PA is currently set to) and it wont update PA everytime
so command needs to run once, then update pa, then run again etc. etc. etc. untill you if exist command stops finding things existing and stops the batchfile running
Old Sep 15, 2004 | 03:01 PM
JohnnyB's Avatar
JohnnyB
Me and dos bat are not friends
tar mate
Old Sep 15, 2004 | 03:02 PM
JohnnyB's Avatar
JohnnyB
I see what you mean Jim bob
I think I need to think about this
Old Sep 15, 2004 | 03:03 PM
JohnnyB's Avatar
JohnnyB
not as easy as first thought
Old Sep 15, 2004 | 03:08 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
heres an example if u aint already done it?
To change the name of the file SALES.TXT on drive A to NEWSALES.TXT on drive A, enter
ren a:sales.txt newsales.txt
To change the filename extensions to TXT on all files on drive B that have SAL as the first three characters of the main filename, enter
ren b:sal*.* sal*.txt
Old Sep 15, 2004 | 03:09 PM
JohnnyB's Avatar
JohnnyB
Wait a minute it does not matter that they are the same when they get first called
as the ones in the afternoon will be different
Old Sep 15, 2004 | 03:14 PM
JohnnyB's Avatar
JohnnyB
tar vrooom
Old Sep 15, 2004 | 03:15 PM
JohnnyB's Avatar
JohnnyB
fookit I will use Colur factory
Thanks for all your help
Old Sep 15, 2004 | 03:16 PM
vroooom ptssssh
It Wasnt Me!
Np
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
gingeRS
17
Oct 2, 2015 09:42 AM
rsguy
44
Sep 29, 2015 03:29 PM
