Block liners
Old Apr 9, 2007 | 07:00 PM
escossie560's Avatar
escossie560
Default Block liners
Just after a bit of advice, following my post with reguard to my block fucking up with style on number 4(nice little crack) I have looked at the cost of a new block,if i can even get one i could go for nilesic liners.......
This is were i need advice i have heard there are issues with ring seal and would they be good on a road car or are they race only/realy big power.
The other option is normal liners but are these any good at 500 bhp ish plus gas.
cheers in advance andy
Old Apr 9, 2007 | 07:06 PM
DROPTOP's Avatar
DROPTOP
how much work is involved to liner a block?
Old Apr 9, 2007 | 07:09 PM
rapidcossie's Avatar
rapidcossie
Nikasil liners?
check out the Mountune website for prices
Old Apr 9, 2007 | 07:10 PM
DROPTOP's Avatar
DROPTOP
what about fitting?
Old Apr 9, 2007 | 07:18 PM
escossie560
Originally Posted by DROPTOP
what about fitting?
from what i can see its a major over bore then a steel tube is pressed in at a massive pressure then rebored to size, sounds simple..........but im sure there are more things to think about, somebody must have done it?
Old Apr 9, 2007 | 07:23 PM
DROPTOP's Avatar
DROPTOP
who does it and at what expense? mine doesnt even use liners at all so im going to worry when the boost guage rises
Old Apr 9, 2007 | 07:29 PM
escossie560
it is expensive but at the moment there are not many new 200 yb blocks left ,so prices have gone up. Mine is the ybp so any new block would have to be machined to take oil squirts ,plus long studding and boring all adds up the same looking at options
Old Apr 9, 2007 | 07:33 PM
xr4x4rs's Avatar
xr4x4rs
for standard liners any engineering company can do it
alls it is is over bore the orginal bores for new liners to be fitted
the block is then heated up will the new liners are in liquid nitrogen
once the block is to temp then the liner kegts some silicon sealent and the liners are just hand fitted, they are then pressed into the bore to a required pressure, and any excess silicon is wiped clean,
once after this then they are machined for size of pistons and rings etc and skimmed flush to the block head
nikisl liners id imagine are the same principle except that with the nikisil liner they can take a lot of amount of boost and are very hard and strong so ive heard, the pistons do need different rings as normal rings would jsust be destroyed
prices are around £1500 for nikisil liners to be fitted then you need to get rings to suit your pistons
i dont know how long they would last though
Old Apr 9, 2007 | 07:35 PM
DROPTOP's Avatar
DROPTOP
i'll take my chances
Old Apr 9, 2007 | 07:46 PM
escossie560
This is what i have been looking into, im trying to work out my best options ,from what i can work out the material of normal liners is to a better grade of the block material ,but i am concerned about stability at high power
Old Apr 11, 2007 | 08:25 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
I have between 400 and 500 bhp depending on what my car wants to do on the day
I have a liner in no 2 after melting a piston in Oct last year.
It has held up to 2000 miles of mapping and Scotland road trip.
And then a further 1500 odd miles of hammering to, round and back from the Ring.
Will be on a Rolling Road this Sun, and hopefully at Combe the following Sat. My car gets hammered, and the liner I believe is still in there
Si
Old Apr 11, 2007 | 08:34 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Si
Si, i can understand that statement as when Stu@MSD introduced you to me it was with the comment, "This is SiB - owner of the world's least reliable cosworth"
Old Apr 11, 2007 | 10:10 PM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
...std liners are fine..they are stronger than the original block...i always run them!
Old Apr 12, 2007 | 05:41 PM
escossie560
Cheers for the feed back nice to know im not making a big mistake, think im going for the nikales liners ,ten stud and see how it goes at least then in 12 months i can strap on a gt35 and turn up the boost
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
