rear beam donuts solid, poly std modded what you got...
Old Mar 18, 2007 | 03:05 PM
Mr C's Avatar
Mr C
Default rear beam donuts solid, poly std modded what you got...
fitted to your cosworth? I have a set of alloy rear beam mounts that sit oddly when fitted to my mates shell, the plate that sits across the bottom of the mounts needs washers on the 2x smaller bolts to sit level which isnt ideal, otherwise the plates sit wonky, these are the mounts used;
and this below is how mine fits, it could really use some washers to level it up but the opposite way, on the single M12 locating bolt
I have seen these mounts that look slightly different, they done have the 10mm lip or the locating sleeve in the top, is it a coincident that my mates sits nearly 10mm too far down?
anybody got pics of their car fitted with anything other than standard rubber bushes to compare??
Old Mar 18, 2007 | 04:04 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Old Mar 18, 2007 | 05:05 PM
marco polo's Avatar
marco polo
mr c the first pic are the proper ones the pic that james has put up is the correct way these are the same as mine the market is flooded with them ........lol
Old Mar 18, 2007 | 06:25 PM
Mr C's Avatar
Mr C
glad I used a decent set then Marco Any reason the bottom plate doesnt sit quite flat then should they just be tightened down and not to worry? its as though they are just a little bit too tall.
Old Mar 18, 2007 | 09:15 PM
marco polo's Avatar
marco polo
if you look at this last pic that james has posted this extra bit alloy at the bottom was added to stop crusing the beam mount holders .....................your 3rd pic if you fit them ones they noramlly sqaush the beam mount holders the bottom plate shoud be ike the pic second pic marco
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
3doorcozmess
Sep 7, 2015 01:32 PM
