Closed loop?
Old Feb 17, 2007 | 10:09 AM
Karl 3dr's Avatar
Karl 3dr
Default Closed loop?
Finally finished running the Cossie in now and its ready for setting up, just been reading the post about fuel consumption and a lot of people have mentioned closed loop.
Can someone explain to me what this is, the advantages etc, where's the best place to get it done and how much it would cost roughly?
Any help apprecaited!
Old Feb 17, 2007 | 10:11 AM
Alps Pacino's Avatar
Alps Pacino
Stu's reply on my thread about it
This is a reply i did elsewhere copied and pasted, but 90% relevant to your question.
EVERY car produced in the world since 1992 has had closed loop fuelling control as standard. The benefits of this system, apart from giving great fuel economy (Mine on 900cc Siemens returned 34.4mpg at 80mph) are as follows:
Feedback control for the ecu. Instead of the engine wearing and then you getting the normal cosworth bad idle, my software now compensates for it. No more crappy idle every 3 weeks, in fact, i havent tweaked my idle co or speed for over a year and 15000 miles that i recall. lol
MOT: You will pass an MOT and UK roadside emissions checks, something that incredibly, a lot of cosworth owners still cannot do. lol
Great Cylinder cleanliness. Open up a closed loop controlled engine and you will note it is rather clean. None of this crappy black carbon you see baked all over engines that have old fashioned non closed loop fuelling.
Greater oil and engine life. Overfuelling engines by their very nature dilute the oil and of course this compromises its lubrication ability and then of course your oil thins and the good old YB burns it easier. My last Nurburgring run showed 30laps of the cuircuit, 2000 hard miles and less then 1pint of oil consumed when i got home. Clin d'oeil
My software for closed loop is far better at idle valve and cold control than many tuners non closed loop software as i have dedicated the most time to perfecting it, remember, it was me that did the first ever closed loop for large injectors that worked properly on the Weber L8 with a 3bar in this country with all the correct switch over points and thus doesnt allow a T4 to run 12psi at 15:1 because someone just copied fords control maps for a 2bar with no tweaks for larger injectors. lol.
We know more about this system than most and as a result our software will not give any crappy hunting when cold or poor driveability. In fact, you will be hard pushed to tell if your engines hot or cold with our closed loop software unless you look at your temp gauge. To some owners this alone is worth the extra cost even if the fuel economy isnt.
Money: All this extra cash i have from spending less on fuel, less on tuning and less on oil can be better spent elseqwhere.
Costs vary. But in a nutshell:
Closed loop chip up to greens = Ł250.00 (Extra Ł100 for greys or bigger)
Lambda if you dont have one is Ł80
Exhaust SS Boss if you dont have one is Ł20
95% of 4wd cars have the wiring as standard from 90> If you dont, i will instruct you how to wire it. Its very simple, live, earth and a signal to pin 2 of ecu. This system works with both L8 and P8 although our P8 software is Ł100 less as its always been closed loop from day one.
Hope this has helped.
Wasted spark:
Often known as acoilpack conversion.
This system adds a driver to your level 1,6,8 or p8 ecu that will drive a modern twin coilpack, thus running your HT ignition system in a wasted spark configuration, thus removing the old coil, king lead, cap and rotor arm altogether. This will allow you bigger spark plug gaps and far far less maintainance. The system is also far less susceptible to moisture.
For further info and pricing see here:
http://www.motorsport-developments.c.../iawwasted.htm
Old Feb 17, 2007 | 10:20 AM
Karl 3dr's Avatar
Karl 3dr
Thanks mate! Thats answered a lot of questions!
Old Feb 17, 2007 | 10:34 AM
KregRS's Avatar
KregRS
Might be a stupid question, but does this only apply to Cossies? or can it be adapted for, say, a S2?
Old Feb 17, 2007 | 11:45 AM
Rick's Avatar
Rick
This system is for Marelli ECU's. If your S2 has marelli then this is no problem. Other aftermarket ECU's can run closed loop too.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
pabloXR
Sep 21, 2015 12:42 PM
tib2220
Sep 14, 2015 12:33 PM
