quick question bout s2.....
Old Dec 1, 2006 | 09:03 PM
b_kennedy's Avatar
b_kennedy
Default quick question bout s2.....
Hi. Can anyone tell me where I can find the following sensors. I have just installed a new loom and the connectors on the engine aren't colour coded so have had to go by wire colours to each sensor. Thanks in advance
1.) Thermo switch
2.) Coolant temp sensor
3.) Cold start
4.) Knock sensor
Old Dec 1, 2006 | 10:04 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
I think these are right but don't quote me
1. is the black box on the side of the metering head near the crankcase vent pipe
2. on the sandwich plate for the injectors
3. I presune you mean the cold start injector if so on on the bottom of the inlet manifold (blue) will have a fuel pipe or fitting on it
4. this IS on the end of the inlet manifold near the brake servo and the connection is green
Hope this is of some help and some one please correct me if wrong
Bri.
Old Dec 1, 2006 | 10:27 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
1) Thermo T/S is brown and on the back of the inlet in the middle under the CSV iirc
2) is yellow and roundabout the same area
3&4 as above.
Old Dec 2, 2006 | 08:59 PM
b_kennedy's Avatar
b_kennedy
Thanks for your help guys. Started first time. cheers
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
