HELP!!..How to change Pug 306 Dturbo Fuel Filter
can someone please give me a step by step guide on changing it please :top: :top:
it's a phase 1 1996 model with bosch pump i think |
Hi Spiky,
when i done mine all i did was undo the 4 bolts take out old put in new and she fired pretty much straight away... i have put a black mark on the photo of where it is if it helps? https://img.photobucket.com/albums/0...tin/filter.jpg Martin |
That's it. It's dead easy. Just remember to prime the system again afterwards :)
also remember the new seal goes around the edge of the filter, not plonked on the top.
.......and if it doesnt start first time you'll need to bleed the system using the hand pump & the bleed nipple!! ;) ;) ;) ;)
i forgot all about that as i had to do it that way the first time i think edited to say maybe i never now as it happens i cant remember :cry: :cry: |
where the bleed nipple?
mmm sounds fairly easy.. :top: something's bound to go wrong :cry: |
Easy peasy dude!!! u doing it tomorrow morn? If so i will pop around and show u on way home from uni..... ;)
The rubber bulb to prime the system is above the alternator
undo 4 bolts
change filter put seal around filter put top back up pump the pump thing :cry: start car??? |
mmm sounds fairly easy.. :top: something's bound to go wrong :cry: it is a genuine piece of piss to do lit 5 mins :top: |
undo 4 bolts
Rhys
got a guy coming to see BM tomorrow morning. then going to get bits and sort the PUG so probably be doing it in the afternoon :top: |
Spiky will give u a bell tomorrow!
cheers guys :top: :top:
I'd prefer to be doing your job than what I'm doing tomorrow - I'm changing the whole engine & box in a 306TD!!!!! :cry: :cry: :cry: :cry: :cry:
well i'm going to be doing the oil and oil filter, so about the same :DD:
not :cry: rather my day than yours :cry: |
all done :top: :clap:
cheers for the advice guys, spot on :top: :top: :top: |
Sound mate!!! :top: :top: :top: :top:
I had a good day aswell for a change!!! Got the engine out, & the new engine in & running today before it got dark at 4:30pm!!! Been at it since 8:30am!!! :cry: :cry: :cry: :cry: Just got the intercooler & coolant system to plumb back in!!! :DD: :DD: :DD: :DD: |
© 2024 MH Sub I, LLC dba Internet Brands
