flat battery
Old Jul 31, 2006 | 01:58 PM
jamieslittleracer's Avatar
jamieslittleracer
Default flat battery
hey sorry to be stupid but i left my lights on, and when this happened before someone put the jump leads differently to how it says in the manual, and so i was jsut wondering how they were supposed to go...
is it red to red and black to black, or my black to earth? thank u sorry i know its stupid
katie x
Old Jul 31, 2006 | 02:03 PM
jamieslittleracer
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
what do you mean black to earth? black on the battery is earth (usually)
look at the signs on the battery
+ = positive
_ = negative
so + - + and _ - _ and you wont go wrong
dont worry if it sparks slightly when you connect the last one, it just means their is a good connection, give them a little shoogle once their on to makesure the connection is good as dirt/grease can give it a bad one.
Makesure they + wires and the _ wires dont touch each other
You could also connect the earth wire on the dead battery car to an engine lift eye or something simmilar
If it doesnt go on the first turn of the key, leave the ignition on and give it 5 mins (dunno what this does but works for me?)
Old Jul 31, 2006 | 02:04 PM
Doug's Avatar
Doug
Red to Red FIRST
Then
Black to Black SECOND
Then remove the Black FIRST Once you have started it
Hope that helps ?
Regards Doug .
Old Jul 31, 2006 | 02:05 PM
jamieslittleracer
thank u
Old Jul 31, 2006 | 02:22 PM
jamieslittleracer
nothing seems to be happening... we have left it for a good 5 mins but it still isnt doing anything... the manual says red to red their black to my chassis?
Old Jul 31, 2006 | 02:24 PM
Doug's Avatar
Doug
Chassis or straight to your negative battery terminal the BLACK one is the other car running ? .
Regards Doug .
Old Jul 31, 2006 | 02:27 PM
jamieslittleracer
both... it has happened before and with the same leads..... any ideas??
Old Jul 31, 2006 | 02:45 PM
vroooom ptssssh
It Wasnt Me!
the leads prob pretty thin?
put the earth from the running car to your exhaust manifold or to an engine lifting hook
all i can think is the connections arent good!
try bump starting it, even with a flat battery it could still work, or get someone to tow you while you bump start it.
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
jay030787
Sep 18, 2015 04:38 PM
