blueprinted engine
Old Jul 21, 2006 | 03:46 PM
andre_k's Avatar
andre_k
Default blueprinted engine
what exactly is a blueprinted engine? i have my ideas but im not 100% sure...
and if it is what i think it is, then why is it any good?
Old Jul 21, 2006 | 04:23 PM
Effectively one built to very exacting tolerances.
For example, ive just built a bottom end for a 450bhp Vauxhall engine, an example of the blueprinting ive done is i have decided on a piston to bore clearance of 3.5 thou, and thats EXACTLY (to within a tenth of a thou) what the clearance is on every single bore all the way up and in every direction, likewise all the weights of the rods and pistons are as exactly the same as i can measure down to.
So basically, it just means that you built it to an exact specification rather than within a wide tolerance like on a normal cheap and cheerful rebuild.
Old Jul 21, 2006 | 04:25 PM
MAD EVO 4's Avatar
MAD EVO 4
well put chip
Old Jul 21, 2006 | 05:03 PM
richard_syko's Avatar
richard_syko
I bought this for mine, http://www.amazon.com/gp/product/188...e=UTF8&s=books
Lots in there!
Old Jul 21, 2006 | 05:10 PM
andre_k's Avatar
andre_k
cheers chip, what i thought
but i have heard, on the grapevine like, that a loose cvh is better for power. if this is true, then why would people blueprint a cvh engine?
what differant machines etc than thouse found in your average engine rebuilding place are needed? Or is it down to the person using them?
Old Jul 21, 2006 | 05:59 PM
What level of looseness is correct though?
1 thou of clearance on a big end? 1.5 on a main? 5 thou on piston to bore?
IF so, then blueprint an engine to exactly that clearance so its all perfectly loose by exactly the right amount
(those numbers are NOT of any relevance by the way, just total random examples)
No fancy tools are needed to build an engine properly, a basic boring bar and a honing bit on a drill is enough if its in the right hands and you have accurate measuring equipment, all fancy machines do is make it quicker to do the same thing really.
Ive got a mate who can hone to withing 1-2 tenths of a thou by hand with a drill, i also know machines shops who cant match that with any of their fancy automated honers, so its all down to who is doing it.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
