difference between 4x4 Cosworth rear diff and XR4x4???
Old May 31, 2006 | 02:41 PM
richm's Avatar
richm
Default difference between 4x4 Cosworth rear diff and XR4x4???
What is the difference if any between rear diffs for 4x4 Sapph and 2.9 XR4x4?
3.62:1 ratio on both.
XR has flat faces on the drive flanges I believe, I seem to remember that Cosworth one may have a recess on the drive flanges to locate with the driveshafts????
Old May 31, 2006 | 02:50 PM
xr4x4rs's Avatar
xr4x4rs
as far as im aware nothing there both exactly the same and same driveshafts
some people put the 3.9 diffs in off the 2.0L xr4x4 and these are a direct swap
Old May 31, 2006 | 03:15 PM
Damocos's Avatar
Damocos
Cossie diffs use 108mm drive flanges, XR's and Granny 24v's got 100mm flanges. Everything inside is the same apart from ratios depending on model
Old May 31, 2006 | 03:22 PM
richm's Avatar
richm
hmm.. so asking a different way then...
are the driveshaft fixing centres the same even though the flange diameter is different? Will the cossie driveshafts bolt up to the XR flanges?
Old May 31, 2006 | 04:02 PM
xr4x4rs's Avatar
xr4x4rs
108mm drive flanges are 2wd and are different
the 4wd cos flanges are the same as xr and granada
Old May 31, 2006 | 04:30 PM
richm's Avatar
richm
Ah cool..
on a different note, how much does a 7" 4x4 diff weigh? i've seen mention of 25kg, but that seems a bit heavy to me??
Old May 31, 2006 | 04:36 PM
xr4x4rs's Avatar
xr4x4rs
havnt a clue mate
but they do weigh some to be honest
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
xr4x4rs
Aug 6, 2015 09:03 PM
Old ford
Jul 31, 2015 06:50 AM
