MOT failed! no rear brakes
my RS2000 failed its MOT on saturday for having no rear brakes :cry:
they said there was little or no effort to the rear brakes, no pressure what causes this? how can i fix it? :top: |
new brakes? :cry:
Didnt you notice the brake performance going downhill though ? :? :cry:
Could be corroded brake pipes or something like that? dout its much anyways ;) |
mabey the bias valve ?
actually never noticed it until going to the MOT test centre! i thought braking felt a bit wierd when i couldn't stop for a roundabout :cry:
Siezed callipers (if it a mk5) ie pistons ect take a calliper off and get a m8 to pump the peddel and see if the piston moves at all ;) Mine you you may want a G clamp or brake tool to push it back in if it work ;)
thanks lads, will check it out ;)
© 2024 MH Sub I, LLC dba Internet Brands
