Testing Ign Barrell - esc cosworth
guya, about to go and check the voltages on the ign barrell
I thing there are 3 wires there and one spare point not used theres a red, black and another cable i cant remember what colour that is anyone confirm the colours of the wires before I journey to the car.... and what they do on each ign click? so I can rule this part of the car out.. cheers |
Dave ther should be 4 wires on the back of your ignition barrel
RED = BATTERY VOLTAGE CONSTANT BLACK/BLUE = TRIGGER TO STARTER BLACK = POSITION 1 IGNITION OUTLET FEED YELLOW = POSITION 2 ENGINE RUNNING IGNITION OUTLET (AUX) Hope that helps . Regards Doug . |
Doug - the first click is the aux, second is ignition. Usually black is igntion live - ie the second click. Above u say second click is aux - thats ignition.
:top: cheers doug and rick
Regards Doug . |
guys, what wire should go live on click 3 (starting)
this i assume is what triggers of the starter motor? black blue yes? |
© 2024 MH Sub I, LLC dba Internet Brands
