Plenum covers interesting....
Old Mar 31, 2006 | 11:24 AM
Default Plenum covers interesting....
...as far as i can see my EEC4 cover is the same width as the 4x4 one.
4x4 = 460bhp
EEC4 = 520plus bhp
So the xtra power is gained from the bigger elbow on the EEC4...quite obvious!....SO it seems the elbow size is the restricting factor....so how does putting a spacer on have any difference in bhp capability to a 2wd/4x4 cover?
Old Mar 31, 2006 | 01:08 PM
Default Re: Plenum covers interesting....
4x4 = 460bhp
EEC4 = 520plus bhp
It dont but it looks Bling & people ask silly questions about it.
Old Mar 31, 2006 | 01:20 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
4x4 = 460bhp
EEC4 = 520plus bhp
Who says it does?
Old Mar 31, 2006 | 02:26 PM
You'd be surprised Mike!!!Alledgedly its about the space between cover and trumpets But i have kinda proved otherwise surely?
Old Mar 31, 2006 | 02:32 PM
4x4 = 460bhp
EEC4 = 520plus bhp
Who says it does?
Mike why argue , no one has ever thought about these things before, then a DIY genius comes along & re-writes the rules. Hes a clever bugger.
Old Mar 31, 2006 | 03:22 PM
Rod.....i dont understand
Mike is asking WHO says plenum spacers work...i am saying some people in the tuning business...i say how can this be with my first post proving it cant be the distance between trumpet and cover it must be the elbow.
Old Mar 31, 2006 | 03:23 PM
Ryan's Avatar
Ryan
i thought it was common knowledge that the elbow was the restrictive part.
so you could put a 50mm plenum spacer on and it still wouldnt flow any more air
Old Mar 31, 2006 | 03:34 PM
Ginge !'s Avatar
Ginge !
just finding my feet
aint the plenum design for torque/responce though and not just about the air flow
or is that a N/A car thing
just asking btw,,,,,as im clearly not a one to discuss this
Old Mar 31, 2006 | 03:35 PM
Turbo lag's Avatar
Turbo lag
can you put a eec 4 front cover on a big turbo back or do you have to change the whole thing ?
Dave.
Old Mar 31, 2006 | 03:41 PM
SPADGE's Avatar
SPADGE
Harvey once told Ian that spacers make very little difference in his experience Phil
Old Mar 31, 2006 | 03:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i've never said that they increase power - i thought that their purpose is to even the flow between cylinders by having them suck from a larger volume.
Old Mar 31, 2006 | 03:55 PM
Turbo lag's Avatar
Turbo lag
Is that a no then
Old Mar 31, 2006 | 04:04 PM
jon@work's Avatar
jon@work
Originally Posted by Turbo lag
Is that a no then
no it's a yes
Old Mar 31, 2006 | 04:14 PM
Jim Galbally's Avatar
Jim Galbally
ginge, it is... but when youre talking about peak BHP, all you're interested in is getting as much air in as possible
Old Mar 31, 2006 | 05:07 PM
scruffythefirst's Avatar
scruffythefirst
I think the spacers make that worse - if you look at the standard set up, most of the air goes under the trumpets for 2 and 3, evening the flow out a bit. With a spacer, the flow goes directly into the trumpets for 2 and 3.
Old Mar 31, 2006 | 05:51 PM
Well it was a well respected tuner on HERE that told me a 10mm spacer would make the 4x4 plenum cover a 500 plus BHPer ...Other lesser tuners also.
So Ryan less of the asthough i am dumb ..i am just goin by tuners advice which i have worked out to be total bollocks
Not good...not good at all.
Stu,Karl???????Explain???
Old Mar 31, 2006 | 07:02 PM
YBP's Avatar
YBP
On a 2wd plenum I guess it´ll have some effect. Otherwise, why make it bigger on the 4x4?
A bigger plenum with the same restrictive inlet elbow might work in theory because you will have less pressuredrop in the plenum on a intake stroke because you have more air in the plenum. Don´t really think real life testing will show any significant gains tho..
Another thing is the "tuning" of the plenum. By altering plenum volume you also alter the pressurewaves created in the plenum by the inletvalves opening and closing. The main idea is to find the volme that will use the shockwave created by one cylinders inletvalve closing to reach the next inletvalve opening, and assist cylinder filling in the rpm range you need it.
Mark RS
Mar 5, 2021 06:08 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fil
Sep 30, 2015 12:08 PM
