How does the...............
Old Mar 23, 2006 | 09:31 AM
gingeRS's Avatar
gingeRS
Default How does the...............
..................door ajar display work on a saff
mine thinks the lights are permanently on (1 headlight and 2 tail). everything else on this display works fine, cold warning, doors etc
please tell me so i can fix it after work today
cheers
rory
Old Mar 23, 2006 | 09:45 AM
big_wig_074's Avatar
big_wig_074
try cleaning up some of the earths on your car,like behind the side panels in the footwells. i did this while fitting a stereo,and before i did it i sometimes got phantom readings,but afterwards it stopped!
Old Mar 23, 2006 | 09:56 AM
Neil S's Avatar
Neil S
The headlamp symbol represents a blown bulb mate. It also tests the brake lamps too - if you put your foot on the brake, the symbol should go out.
Faults with it are likely to be earth related as bigwig says
Neil.
Old Mar 23, 2006 | 10:09 AM
gingeRS's Avatar
gingeRS
cheers guys
will test this tonight
is the box in the pasenger footwell then?
