what year is my engine ?
1 Attachment(s)
hi, i have had a engine transplant and would like to know roughly what year my engine is, im thinking its a early one , think its a 205 block.Attachment 7977
Probably need the engine code to work it out.
87 to 89 choice is yours
The first two letters of the engine number will tell you the year of the manufacture of the vehicle it came from.
My engine number starts GA which makes it November 1986 which is pretty much the last batch of normal 3 doors I'm led to believe. See here - http://www.burtonpower.com/tuning-gu...ure-dates.html |
my engine code starts ybb
That's the engine code. The engine number will tell you the year of manufacture.
ybb18452 ?
that doesn't look like an engine number. That's the number stamped on the front of the block isn't it?
The engine number is on the bottom right hand side of the block just behind the oil filter. |
that is what is on my log book
think i will just call it a 88 engine ha
is it in a car? if it's the original engine it'll be the last 7 digits of the chassis number
Here's a paragraph that explains what each engine type is and what car they were originally fitted into. Your YBB is a Red Top engine, but exactly what year of manufacture it's difficult to tell unless you know the engine number:
The various colour cam covers that distinguished each version were as follows: Red: YBB (Sierra Cosworth 2wd, both 3-door and Sapphire), YBD (Sierra RS500), YBJ (Sierra Sapphire 4wd, non cat); Green: YBG (catalyst equipped 4x4 Sierra Sapphire Cosworth); Blue: YBT (large-turbo Escort Cosworth); Silver: YBP (small-turbo Escort Cosworth). Lifted from - https://en.wikipedia.org/wiki/Cosworth#The_YB_series |
its a escort rs2000 with this engine fitted.
ah, so could be any year between 86 & 88 i guess
Seen that car on eBay looked a decent enough toy, is it clean enough in person?
yeah its clean for the year although not immaculate. good for a 18 year old unrestored car.
That must have been registered incorrectly as the engine number, when it was changed.
The engine number is on the turbo side of the engine (seven characters) Martin |
Presume the 'YBB' number is some sort of casting number, as above the engine number is underneath the turbo. Here's mine
https://cimg5.ibsrv.net/gimg/passion...beefff987a.jpg https://cimg6.ibsrv.net/gimg/passion...5a9d49c72f.jpg |
I think I will call it a 88 ! It's just to order parts when they ask year.
Originally Posted by Michael Dunne
(Post 6689577)
© 2024 MH Sub I, LLC dba Internet Brands
