st200 abs light.
Old Feb 24, 2011 | 09:58 PM
neil andeRSon's Avatar
neil andeRSon
Default st200 abs light.
After having to sell my first st200 a few yr's back I promised myself I'd get another one. Well one came up for sale locally a few day's ago. Went for a look an it's a bit rough around the edges but will scrub up good. Only problem's I have with it are the abs an traction control light's are on. The guy said that one of the front abs bracket's has snapped off the shock. He thought that's why the light's were on. Does anybody know off any prob's with the abs on these?
Also the rear wiper Seem's to be on all the time. Is anybody aware of any prob's with them?
Old Feb 24, 2011 | 10:04 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
That'll be the ABS pump, can pick um up for Ł40 ish but fitting the fucker is another matter.
Old Feb 25, 2011 | 12:48 PM
neil andeRSon
Are they a bastard to do then?
Old Feb 25, 2011 | 12:52 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Yes mate, you have to remove -
Battey
Inlet box
Brake servo
to get to the pump
then the fuckers need re-programming from what I remember and the bleeding pattern isnt strate forward once changed.
Old Feb 25, 2011 | 01:08 PM
neil andeRSon
Oh joy! Here's hoping it's just a sensor. Lol.
Old Feb 25, 2011 | 01:23 PM
carlfiesta999's Avatar
carlfiesta999
Tape over the bulb job
Old Feb 25, 2011 | 03:15 PM
bookwyse's Avatar
bookwyse
And an instant MOT failure with that approach.
Could be the sensor which are prone to going and a simple fix. Just WD40 well before trying to remove the old one.
If it has snapped the bracket then it is a new hub as they bolt onto the hub not a huge job again.
The ABS pump however is a diffrent issue as they are a real pain to do.
Old Feb 26, 2011 | 07:09 AM
carlfiesta999
I know, mind you saying that my mate binned his 05 reg focus into a kerb trying to get away from someone (long story) and set his seat airbag off, he just taped over the light and had the seat stitched back up while he saved to get it fixed.passed an MOT too :/
Old Feb 26, 2011 | 11:45 AM
bookwyse's Avatar
bookwyse
Airbag light isnt a failure whereas the ABS light is specifically tested. not all cars have the airbag lights whrereby all HAVE to have the ABS one
Old Mar 1, 2011 | 12:49 PM
neil andeRSon
The front drivers side sensor lug has snapped off the hub. That'll be that problem then.
Will the hub off a 2.0si be the same?
Old Mar 1, 2011 | 02:08 PM
DJMST's Avatar
DJMST
SHELL GARAGE VIP
the V6 hub maybe bigger,Im sure the driveshaft is thicker,so the spline wont fit
Old Mar 1, 2011 | 04:12 PM
bookwyse's Avatar
bookwyse
Correct has to be either a diesel or another V6 hub i'm afraid.
Whereabouts are you as I have one sat in the shed.
Jeff
Old Mar 1, 2011 | 04:17 PM
neil andeRSon
Jeff
Am in the shetland isles mate. How much would you be lookin for it?
Old Mar 1, 2011 | 05:57 PM
bookwyse's Avatar
bookwyse
Will see how much postage is mate and get back to you.
Old Mar 2, 2011 | 08:41 AM
neil andeRSon
Cheer's mate.
Old Mar 4, 2011 | 02:40 PM
neil andeRSon
Cool
Did you find out a postage cost?
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
