St170 tapping noise
Old Jun 13, 2014 | 09:17 PM
LeeBee's Avatar
LeeBee
Default St170 tapping noise
Hi I have a tapping noise from my engine bay on my st170, I only really hear it on tickover, it might do it as I rev the engine but I can't hear it. I thought it could be the DSI clip or the imrc unit, but as I have no engine light come on I am now stuck on ideas. Any help on this would be great, thanks
Old Jun 13, 2014 | 11:11 PM
hydro st170's Avatar
hydro st170
In expert but mine makes that noise like a rattle but if i put my foot on the clutch it goes away so ive been told by a mechanic that is the bearing in the clutch so he said get a 3 piece clutch and that will b problem sorted.Dont no if its the same as urs but hope this helped
Old Jun 14, 2014 | 07:40 AM
LeeBee's Avatar
LeeBee
Nah it's not clutch rattle. Cheers
Old Jun 14, 2014 | 09:03 AM
louis_2012's Avatar
louis_2012
As you stand looking at the engine, look down the right hand side of the block towards the back with the engine running, the previous 170 i owned the cable/cable clip snaps off the inlet and the clicking noise you can hear is the cable going in/out/in/out as the IMRC is trying to adjust the inlet flaps but cant due to it being snapped off. Also to note the injectors are quite noisy on these.
Old Jun 14, 2014 | 09:41 AM
LeeBee's Avatar
LeeBee
This was my original thought, but as the EML isn't on I figured it wouldn't be this, everything I've read says the EML would be on
Old Jun 14, 2014 | 09:43 AM
LeeBee's Avatar
LeeBee
Also there is no loss of power atall.
Is it possible that it's because I have put a vernier pulley at -6 degrees on the exhaust cam? That would essentially make the inning slightly lumpy on tickover right? Although doesn't make much sense of the ticking
Old Jun 14, 2014 | 10:21 AM
MJ_RST's Avatar
MJ_RST
Its hard to say without hearing it, but all ST170's have a light tapping sound, best described as the noise of injectors ticking.
Old Jun 15, 2014 | 10:44 PM
LeeBee's Avatar
LeeBee
The tap/knock has gone, but as mentioned the injectors are pretty loud, also, since fitting the vernier exhaust pulley it sounds 'poppier' at lower rpm, I'm guessing this is normal as the exhaust timing had been changed, it runs sweet higher up the range but I just wanted to check. As it said before the EML isn't on and it has plenty of oil, so I'm guessing it's either because of the vernier, or just age related?
Thanks
Old Jul 27, 2014 | 02:24 PM
arkeye's Avatar
arkeye
Mines just started to do this, annoyingly I thought it was Cambelt related so this weekend I just replaced all the rollers, tensioners etc. will ignore it then and wait for the clutch to go.
It rattles on idle when warm. If u rest your foot on the clutch it gets a tad noisier but when you fully press it down, nothing.
Old Jul 29, 2014 | 01:18 AM
hydro st170
Yeah same as mine.Mines going this weekend get new clutch in.Ill let u know how it sounds after.
Old Jul 29, 2014 | 12:13 PM
arkeye's Avatar
arkeye
Are you going for a single mass fly? That's what I'll do, can't justify the price of a dual mass kit
Old Jul 29, 2014 | 04:52 PM
hydro st170
No im putting in a new dual mass flywheel.Ive heard of people putting in a soild flywheel and they where getting some bad vibrations cause of it so i think spending the extra now will save in the long run and i wouldnt wont the hassle of having 2 replace a solid 1 if id just put 1 in.
Old Jan 19, 2016 | 11:40 PM
wombat76's Avatar
wombat76
AFAIK the st and rs had a specific oil filter, i got a std filter when i changed the oil and afterwards i had what i would say was tappety noise before the oil got to the top end of the engine, lasted about 6 secs, changed to pukka filter and it is now 3 secs or less still annoys me as its oil not getting to the head or draining while sat up and when the starter motor cranks all to life the noise starts.. again its not hydro tappets but solid to the best of my knowledge, ran it past an Expert Ford man and he said, its a zetec.. they do that!!!
Old Jan 19, 2016 | 11:44 PM
wombat76's Avatar
wombat76
as to hydros worry over the dmf, petrol engines don't need dmf and the 2.0 16v has std single flywheel with no issues, lets not forget that it was the usa Ford guys who designed this machine, and they who got the getrag involved. i'm about to mod mine with a full 2.0 16v mtx75 kit from a full car i bought for the job,,. Hydro i'm local to you 60 miles down the road, coleraine.. give me a shout..
Old Dec 4, 2017 | 03:50 PM
Mustard1980's Avatar
Mustard1980
Hi All! New to the site and this is my first post but felt I might be able to help or at least share my experience....
I've got 2004 ST170, same problem, odd rattle at idle, which disappears when I either put my foot on the clutch or drive off. I have changed my clutch to a sprung loaded plate and single mass, light weight fly (Thanks to TurboSport).
I was told about the vibrations and extra noise from the single mass fly but don't have either of those issues. I was told my issue was the idler pulley bolt working loose which I replaced and it cured the problem. There was also times when the car would idle fine then as either the fan cut in or I turned on the A/C the noise would start. New idler bolt...done....
On another note, lightweight fly has really helped the car rev freely and I've gained an extra 85 miles of range in fuel economy!
Old Dec 29, 2017 | 07:57 PM
Pwrs2k's Avatar
Pwrs2k
If you dont mind me asking how much was the clutch and flywheel as i was going to replace mine with mew duallmass but read singlemass helps to rev more freely but also read the vibrations are terrible.
Old Dec 29, 2017 | 08:14 PM
Mustard1980
The flywheel from TurboSport cost Ł275, new flywheel bolt price I can’t remember, a few quid each I think. I bought the clutch, slave cylinder and spring plate from Euro Car Parts for Ł216 with my discount code I sometimes get. Worth noting the following if you want to do this... make sure the clutch plate you buy is sprung loaded to take the strain off the crank shaft on hard pull always off the line. Also, if you replace the cylinder make sure you use the o ring on the old one or buy a new as the kit I bought never had a new one and didn’t think about it until I’d fitted everything and filled the gearbox with oil which then leaked through the space!! Finally, TurboSport where by far the best priced for a solid lightweight fly but remember that the ST170 had 2 different clutch sizes throughout the year range so check which yours is, 220mm or 240mm and tell TurboSport as they do the fly to suit. Apart from that, no other issues. No vibration. Better revving, nicer through the range and better fuel economy.
Old Dec 29, 2017 | 09:23 PM
Pwrs2k's Avatar
Pwrs2k
Ok thanks for the info mate just a few people have mentioned about that chatter noise you get on tick over.
Old Dec 29, 2017 | 09:32 PM
Pwrs2k's Avatar
Pwrs2k
Seen that puma speed do a ttv lightend flywheel with organic sprung clutch for Ł650
Old Dec 29, 2017 | 10:21 PM
Pitbull69's Avatar
Pitbull69
is the idler bolt a big job ? I have a TTV single mass flywheel and uprated clutch, and its noisy as hell on idle,
Old Dec 30, 2017 | 07:47 AM
Pwrs2k's Avatar
Pwrs2k
Are you using a sprung clutch mate.
Old Dec 30, 2017 | 11:46 AM
Pitbull69's Avatar
Pitbull69
I am using a TTv lightened fly and Sprung Organic Clutch, might be cheaper if your looking to go via TTV direct, thats what I done.
http://ttvracing.com/product/ford-st...lutch-package/
Old Dec 30, 2017 | 12:24 PM
Pwrs2k's Avatar
Pwrs2k
Do you get any chatter noise with yours mate.
Old Dec 30, 2017 | 01:25 PM
Pitbull69's Avatar
Pitbull69
yes lots, thats why I asked that guy above about the idler bolt just incase that is an issue with mine, but if its a big job I will leave it, I was told I would get noise with it, and even queried it with TTV about just how much noise there was,
Old Dec 30, 2017 | 01:30 PM
Pwrs2k's Avatar
Pwrs2k
If you get noise even with sprung clutch think i will stick with the dualmass as its a road car that noise would do my head in lol.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
