ST170 spacers
Old Aug 16, 2013 | 05:49 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Default ST170 spacers
Hi,
I was just wondering, basically I want to tweak the set up of my ST170, lower it a little, stiffen the ride a bit, reduce the body roll, but...
Basically I find the 17" alloys are a little inset under the wheel arch, so is there a better way to bring the wheels out a little so they fill the arches more, especially the rears. I don't want to buy those cheap 5mm spacers that go behind the wheel.. so any advice ?
Regards Paul
Old Aug 16, 2013 | 06:15 PM
DavebST170's Avatar
DavebST170
What about proper hub centric spacers? They arent cheap but they work really well
Old Aug 17, 2013 | 10:39 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thanks, that's exactly what I want
Now to work out what size I want..
Old Aug 17, 2013 | 12:35 PM
RichieST's Avatar
RichieST
Hubcentric spacers will be fine, however I think they will make the handling worse, it will bump steer more and will wear wheel bearings quicker.
Old Aug 17, 2013 | 12:43 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
What other options are there Richie ? different offset wheels ?
Old Aug 17, 2013 | 05:39 PM
RichieST's Avatar
RichieST
Spacers will have exactly the same effect as different wheels with a lower offset. I've got hubcentric spacers on my ST, only because the RS wheels are a higher offset, so they need spacing out to get it right.
To be honest if you were to go 10mm or something I don't think you would notice on the road, but I would be inclined to leave it as is!
Old Aug 17, 2013 | 07:33 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Cheers Richie, it was more for aesthetics than anything else, so I will leave it
Old Aug 17, 2013 | 08:11 PM
STeve's Avatar
Super Moderator
I changed my high et standard wheels for et35 and fitted 25mm hubcentric spacers and it filled the arches nice and handled well tbh
Old Aug 17, 2013 | 09:11 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Really... that's interesting, was it on a Focus ?
Old Sep 9, 2013 | 12:33 PM
borinous's Avatar
borinous
what about these? http://www.pumaspeed.co.uk/product-R...e-10mm_231.jsp
Old Sep 9, 2013 | 03:37 PM
MJ_RST's Avatar
MJ_RST
As above, use hub spacers, ive got a set of these. The only issue youl have is if the rear subframe is corroded etc
Old Sep 9, 2013 | 03:48 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thanks, I will give them a go
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
