St170 Advice
Old May 30, 2011 | 05:12 PM
c14aff's Avatar
c14aff
Default St170 Advice
Hi all.
I have a 53 plate st170 that has now covered 78k.
All has been well but of late noticed it's abit lumpy on idle, but clears if i raise the rpm slighty.
I also notice at 2500 rpm it feels if it's slighty holding back underway, but again if you put your foot down it clears.
Any idea's?????
Thanks
Dan
Old Jun 16, 2011 | 08:24 PM
siany1997's Avatar
siany1997
Originally Posted by c14aff
Hi all.
Any idea's?????
Thanks
Dan
Can't comment on the lumpy idle, but mine definately doesnt like 2.5k either. Burps, farts, stutters and generally tells me to get away from that rpm, particularly on a constant throttle.
Don't drive at 2500rpm
Old Jun 16, 2011 | 09:26 PM
kyle_st200's Avatar
kyle_st200
Its usually the fuel pump in the tank thats at fault when it hesitates at 2500rpm. Do you find it normally does it when the fuel is nder 1/4 tank? Id probably say its going to be lambda sensor causing lumpy idle etc,common on these
Old Jun 18, 2011 | 09:17 PM
minder's Avatar
minder
try cleaning the throttle body out over the years they cake up with soot and start to stick untill you put your foot down. will take you no longer than 30 mins max to do the job
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
