focus speedo
Old Jan 23, 2008 | 07:03 PM
krill's Avatar
krill
Default focus speedo
Hi, I have a 1999 1.8 ford focus, the speedometer stops working occasionally and when this happens the engine runs a bit rough, when the speedo starts again the engine picks up, any ideas please?
Old Jan 24, 2008 | 09:18 PM
Lobby's Avatar
Lobby
Exactly the same thing happening to mine, My mechanic friend said it's prob the transducer which he said will be about ?75 odd, iff not then the actual speedo ?115 odd i think. ECU check should tell you.
Lobby
Old Jan 25, 2008 | 11:49 AM
Big AL's Avatar
Big AL
Its the VSS (vehicle speed sensor), quite a common problem. Would recommend replacing asap as when speedo drops and engine cuts then no power steering or brakes.
Old Jan 25, 2008 | 02:55 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
^^As above^^
It's a common problem, if you're lucky it's an easy fix but quite a few people have had nightmares with it as the securing pins have snapped or seized and then it becomes a gearbox off job!
cossie brad
Sep 29, 2015 02:38 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
