Focus 2.0l Zetec Engine Code???
Old Dec 11, 2007 | 04:32 PM
MattPym's Avatar
MattPym
Bothuurd
Default Focus 2.0l Zetec Engine Code???
Does anyone happen to know the engine code for a 2.0l Zetec from a Focus (Series 3, Blacktop Engine)....Thought it was NG but apparently it is'nt
Matt
Old Dec 11, 2007 | 11:44 PM
pdfbt40's Avatar
pdfbt40
NGA & NGB are the 2.0l engine codes for the Mondeo...
The Focus 2.0l engine codes are EDDA, EDDB, EDDF, EDDG...
If you discount the ancillaries, exhaust & TB, the only significant difference, is the 'coolant' sensor. The Focus uses a CHT and nothing in the thermostat housing; the Mondeo has a sensor(s) in the thermo housing. The Mondeo head has the tapped hole for the CHT, its just not used.
Old Dec 12, 2007 | 05:24 PM
MattPym's Avatar
MattPym
Bothuurd
Cheers, Thanks a million
Are the last letters in the 'EDD' codes just emmision standards like the mondeo codes???
Old Dec 13, 2007 | 01:18 AM
pdfbt40's Avatar
pdfbt40
TBH, I don't know.
The first engines (6/98-10/99) had 2 idler pulleys on the cambelt at the 'front' of the engines (and a version of the alloy camcover). The engines after that had just the single idler at the top of the belt run. The idler bearing and centre mount was revised, as was its position on the head. The head casting was modified to add metal in the waterway for the bolt. The oilpump has always retained the bolt hole for the lower idler
I can't think of any engine mods related to the emission standards. The changes from ECC-1 to ECC-IV happened around 3/2001 (a few months before 'facelift'). This is when the post-cat lambda sensor was added and the PCM codes revised to reduce overall emissions during warm-up.
Oh, and another piece of (useless) information. The steel lower sump (oil pan) differs between the Focus and Mondeo engine. The gap for an exhaust pipe/cat is about 1cm narrower on the Mondeo, and it doesn't have the 'bump' at the pulley end. So a Focus sump wont fit into a Mondeo, but a Mondeo sump will fit in a Focus......although an ST170 or RS cat is a bit tight.
Old Dec 13, 2007 | 10:58 AM
MattPym's Avatar
MattPym
Bothuurd
Cool, Cheers
jaysoc1
Aug 20, 2015 08:18 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
