Rear tyre oddity?
Old May 8, 2006 | 12:59 AM
Tobester's Avatar
Tobester
Default Rear tyre oddity?
Hi all,
My FRST runs on Avon ZZ3's and a mate of mine runs on Goodyear Eagles and we've both experienced the same odd tread wear on the rears. While the outside edge and centre are fine the inner shoulder wears out a lot quicker and in blocks (as opposed to even wear around the tyre). Any ideas as to why this is? His has done less than 30k whereas mine is getting on for 60k now so I'm guessing that it's not down to suspension or bearing wear? I'd like to get this sorted before I splash out on some Yokohama Paradas.
T
Old May 8, 2006 | 05:19 AM
kmrobertson3's Avatar
kmrobertson3
I think this is meant to be mate. When Ford set up the FRS suspension they did it with negative camber to aid in better cornering and better handling.
My FRS tyres wear more on the inside aswell, only thing I can suggest is to change them over with the fronts about half wear.
Go back to the Ford sales pamphlet or early write ups on the car and read up about the negative camber suspension set up.
Hope this helps you
Old May 8, 2006 | 10:31 AM
Tobester's Avatar
Tobester
That would certainly explain it! Thanks a lot
Old May 8, 2006 | 05:33 PM
THEDMAN's Avatar
THEDMAN
It is not un-common for back tyres to look like 50 pence pieces when you take them off!
Old May 8, 2006 | 07:51 PM
MATT222's Avatar
MATT222
std on all focus's even the 1.4s do it !! can even sound like the rear wheel bearings are fucked!!
Old May 12, 2006 | 09:40 AM
Willow's Avatar
Willow
i had this issue - when ford did a service i had a soft front offside damper - they replaced it for me and since then the wear has been better.
Kam B
Sep 24, 2015 10:40 AM
S3an
13
Sep 13, 2015 10:01 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
cossirob
Sep 3, 2015 09:17 PM
3dr cossie
Sep 2, 2015 08:58 PM
