Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
focus 2006 non start help ford techs
Old Jul 21, 2012 | 10:04 PM
carlos1395's Avatar
carlos1395
Default focus 2006 non start help ford techs
hi all i have a 2006 focus 1.6 petrol that i bought needing a engine. the engine i got was from a automatic i swopped the flywheel over and fitted the engine but the car wont start .theres 2 problems ive found no spark and no fuel .fuel pump primes but there is also a trouble code p0336 crankshaft sensor position sensor a circuit range/performance.
ive replaced the crankshaft sensor but still non sart .ive also noticed that the starter motor can crank for 2 then cut out or 10 seconds and cut out .
any help would be greatfully recieved
Old Jul 23, 2012 | 08:42 PM
carlos1395's Avatar
carlos1395
anyone guys
Old Jul 23, 2012 | 08:49 PM
CBenno's Avatar
CBenno
Are all the earths connected back properly?
Old Jul 23, 2012 | 09:48 PM
RSargie's Avatar
RSargie
Car will only supply fuel and fuel and spark, if crank pattern is correct. You've already told us the problem in your post. No crank signal.
track.focus'd
Aug 12, 2015 05:53 PM
