Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
MK1 Focus 1.6 engine stalling?
Old Apr 22, 2015 | 11:11 AM
anthony lea's Avatar
anthony lea
Ford allegiance
Default MK1 Focus 1.6 engine stalling?
This morning when slowing and dipping the clutch to change down to second gear to turn into a side road my engine cut out and hence the power steering didn't work and luckily i managed to re start it in time to carry on driving.
It also does this when approaching lights and dipping the clutch before coming to a halt the engine will die. This is happening more often, once or twice a week maybe. The battery is a Bosch item, relatively new and my voltmeter is showing high 13's/low 14's most of the time and it doesn't struggle to start in a morning.
Can anyone diagnose the problem?
Battery/alternator perhaps?
Cheers.
Old Apr 22, 2015 | 06:37 PM
RichieST's Avatar
RichieST
Sounds like the idle control valve is sticking. You could try cleaning it but I'd replace it.
Old Apr 22, 2015 | 06:57 PM
chris cdti's Avatar
chris cdti
On the 1.6 the idle air valve is on the front of the manifold
Old Apr 23, 2015 | 07:45 AM
anthony lea
Ford allegiance
OK fellas thanks for that
It's also beginning to jerk sometimes. Last time it did this i changed the coil pack but that didn't help so i cleaned the MAF sensor with electrical contact cleaner. This seemed to do the trick as i was concerned that it was coated with the 'tacky' spray that i'd coated a pipercross panel filter with so i changed it for a K&N one so i suppose the coating off that could have done a similar thing over the last couple of years?
Lastly, best place for a new idle control valve?
Cheers guys...
Old Apr 23, 2015 | 01:45 PM
anthony lea
Ford allegiance
Can anyone advise the best way to go about cleaning the idle control valve as Ritchie mentions?
Which cleaners?
Will i need a new gasket?
Thanks in advance...
Old Apr 23, 2015 | 06:37 PM
RichieST's Avatar
RichieST
Soak it in brake cleaner overnight then a very light oiling with wd40.
Old Apr 24, 2015 | 07:49 AM
anthony lea
Ford allegiance
Richie, do you know where I may be able to buy a new gasket?
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
dlwarrior
Aug 5, 2015 10:19 AM
