90 Spec
Old Dec 3, 2005 | 05:38 PM
RST Ski's Avatar
RST Ski
Default 90 Spec
Will 90 Spec dash panels (around radio ,speedo ect) fit on my 86 rs?
Old Dec 3, 2005 | 05:56 PM
im pretty sure they do. but im not 100%
James Raby's Avatar
James Raby
yes, exactly the same
Old Dec 3, 2005 | 07:28 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
depends if the 90 spec had a fuel computer, if it does u'd need to swap over the lil cubby hole bit (they never stick ), also u may be left with a hole if the 90 spec bits had a heated screen button
it will all phisically fit tho
just the options that make the odds
Old Dec 3, 2005 | 07:44 PM
RST Ski's Avatar
RST Ski
cool, the loom for the speedo the same?
Old Dec 3, 2005 | 07:47 PM
1.9 xr2 on 40's
st170 breaking
never had the need to swap em between the styles mate so cant help there, some say they are some say they aint
worth a try i spose, they read same with either set fitted then ur away, just take them old 1's out and plug new uns in to check they are a go'er
Old Dec 3, 2005 | 09:52 PM
DannyDK's Avatar
DannyDK
Nope, the model from 86 to 87 is a litle bit different, if you want to have your gaz and heat gauge to work like it should, you need to fit them reverse(dont know why they made them like that) they dont work proberly if you just fit them in, one of them will go straight to the top and the other one will try to turn the uppersit way, wierd i know
Old Dec 3, 2005 | 10:48 PM
James Raby's Avatar
James Raby
petrol gauge and water gauge work whatever one you put in - honest to god cos done it myself
Old Dec 4, 2005 | 10:17 AM
DannyDK's Avatar
DannyDK
If you look closely on the back you can see a "serial number" wich is either AB-86 or AB-88 and they dont fit! I know that you can take the hole instrument and change that, but then you WILL have the problem. Look if the gauges sits the same place(heat and gaz)i cant remember which one has the petrol sitting to the right or left. Check also the gauge it self, take it out and you will se a MAJOR difference in the two. Think that Ford used the last of the mk.3 mechanic for the first mk.4 on the market. There is also a difference in the digi clock elements(if you have ever opened one of those)then you will(again)see that its rater old parts inside(just like the gauges in the instrument). Another thing they also have used from the mk.3 is the bootlid, there you can see that the wirering for the washer and bootlight comes from the midle(just like on the mk.3)and not in the upper left corner like on a "normal" mk.4. They also used the "brown" tintet widows from the mk.3 on the first mk.4 they made. The reason i know this is because i have an mk.4 with alot of mk.3 parts on/in it(no it has not been fitted by the old owner, why should he). If you dont believe what i say i will see if i can get some pics up on this site.
Old Dec 4, 2005 | 10:26 AM
RST Ski's Avatar
RST Ski
wkd cheers, think il jus get the same as wot ive got instead of converting to a l8r spec
Old Dec 4, 2005 | 10:30 AM
James Raby's Avatar
James Raby
Doesn't matter what set of clocks you have, it will know what's what - don't argue when I know I am right lol
Also, why are you mentioning th mk3??
We're talking mk4 here...of course the mk3 is different, we ALL know this
Old Dec 4, 2005 | 10:55 AM
DannyDK's Avatar
DannyDK
Please rea what i wright, i sayd that my mk.4 has alot of mk.3 parts in it, cant you read!? And NO it wont know anything if your car is a 86 or 87 and you put in a 88 - 90 instrument in it, you have to take out both the petrol gauge and the heat gauge and swap place. That you would have known if the car you have swapped it in where on of the very first mk.4 and wanted to fit the instrument from a 88-90 mk.4. By the way, are you saying that they also looks completly the same? couse then you are in for a big suprise, they dont! Its not much that differs the two but they are different!
Old Dec 4, 2005 | 10:58 AM
DannyDK's Avatar
DannyDK
And i will ofcourse put up some pics of them both, and then i would like for you to say that you are sorry for stupid lame ass attacks when im only trying to help out!
Old Dec 4, 2005 | 12:11 PM
James Raby's Avatar
James Raby
Well, how come on the 4 escort mk4's I have had it don't matter what instrument cluster you put in - it works!!
I know the backs are different, I am not saying they are not
You're being lame, I'm purely telling the chap asking it WILL work no worries
Old Dec 4, 2005 | 02:20 PM
DannyDK's Avatar
DannyDK
ok, so i am the only one that had probs when i swapped the 86-87 instrument to a 88-90? I had to put the heat gauge where the petrol gauge is. Just look at the white dials you can buy, some have the heat gauge to the left and some to the right, now that should be a big mysterie then.............
Old Dec 4, 2005 | 02:22 PM
James Raby's Avatar
James Raby
Not really, the design is different indeed
When I had the fuel gauge on the right, I had a problem because I needed it on the left so I could put a gauge in where the wter temp was (electronic one)
I got some of the newer spec dials and plugged in to see if I could use them, it worked fine so just used them
I did not change any of the wiring at all, neither did I have to swap anything over
Don't mean to be rude, but you really are making yourself look like a right cock, I am right, I KNOW I am right, so just don't argue about it
You have some mk3 parts, that's why it's so fvvcked up mate
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
