Someone with rs knowledge help !
Old Sep 30, 2005 | 05:43 PM
BILKO's Avatar
BILKO
Default Someone with rs knowledge help !
right your all gona probably say "stupid idiot " but i really dont have that gooda knowledge yet about rs turbos
have just bought a nomad boost gauge and forge motorsport in car adj boost.
the kid who had this before me put a bleed valve under the bonnet,
can i just replace the bleed valve with the new boost adjuster and lenghten the pipe?
also where is the best place to plumb in the boost gauge ? is it between the actuator and the bleed valve or onto the third exit on the forge adjustable boost valve?
cheers if someone can help
Old Sep 30, 2005 | 05:52 PM
GrimmeRS2K's Avatar
GrimmeRS2K
yes just lengthen the pipe
boost gauge can t-piece into the right hand side vacuum pipe on the inlet manifold
Old Sep 30, 2005 | 05:59 PM
BILKO's Avatar
BILKO
where the thin pipe from the dump valve goes ?
Old Sep 30, 2005 | 06:01 PM
GrimmeRS2K's Avatar
GrimmeRS2K
yep
Old Sep 30, 2005 | 06:12 PM
BILKO's Avatar
BILKO
cheers m8
Old Sep 30, 2005 | 06:43 PM
Oranoco's Avatar
Oranoco
Personally I wouldn't bother with the adjustable boost controller. Just learn to not be so lead footed.
Take the guage feed from one of the top pipes on the inlet fannimold. Make sure you mount it somewhere easily visible while driving you don't want to be looking at your feet thinking "Hey 20psi" cos it's usually followed by "Oh fuck!" BANG!
Old Sep 30, 2005 | 11:35 PM
BILKO's Avatar
BILKO
i got a coin cup cover for the gauge so its in a good place of view,
i only got the adjustable boost because im planning a major engine upgrade in the near future so i thought i might as well start getting the things needed.
(AND IT LOOKS NICE !!!)
just out of interest what does a standard turbo lump run at in PSI ?
Old Oct 1, 2005 | 11:55 AM
BILKO's Avatar
BILKO
right plumbed in the boost gauge and its reading 15 below on idle ?
Why is this?
Old Oct 1, 2005 | 11:56 AM
BILKO's Avatar
BILKO
Does anyone have i good pic of there engine bay where i can see this clearly ?
Old Oct 1, 2005 | 12:24 PM
Micky's Avatar
Micky
15 below on idle is normal!!!Standard maximum boost is 7 psi Regards Micky
Old Oct 1, 2005 | 01:21 PM
BILKO's Avatar
BILKO
martynhomer01
Dec 12, 2023 07:46 PM
SMILER258
48
Jul 17, 2019 10:08 PM
Flatlinedan
Sep 18, 2015 12:41 PM
1300gt
18
Sep 11, 2015 10:03 PM
