Disaster pls HELP
Old May 29, 2005 | 01:01 PM
rs s2 87's Avatar
rs s2 87
Default Disaster pls HELP
Front mount intercooler, why did I ever get one because a double capacity intercooler would of being fine!!!
Yesterday, I decided to fit my new front mount intercooler(Radteck, which is ok I know not the best but reasonably priced)....I fitted a new alloy radiator about 2 weeks ago and I was running on a standard Ford intercooler. The car was running ok at abount 11 psi.
I wanted more boost so I said I better fit a new intercooler which I did sort off...
Everything seemed to be fine after about 2hrs of fitting/ arsing around...Looked cool, then the moment of truth...Started the engine.....You know when the belt is loose and you have this screaching or wining noise... I said fook. After 2-3 minutes, the motor burnt out on the fan and it bust a hole in the radiator
How I fitted same: I put the fan(spal fan which I think is a slimline, looked smaller the the original, which was the size of a fan in your kitchen!!) on the back of the radiator. I knew it was tight to the turbo and actuator but where else could it fooking go...The motor on the the fan, the metal bar which is in the centre of the fan motor was rubbing of the radiator and bored a hole in the back of the radiator
Pls can someone give me the correct procedure to fit a front mount intercooler, what parts I need, spacers if needed, what gap should between the fan and turbo, what size fan i.e. 7 inch/ 10 inch what dept etc, where should the fan go on the back etc.....In advance, thanks for your help.
Old May 29, 2005 | 01:24 PM
james_birch's Avatar
james_birch
when i fitted mine (radteck) i fitted the fan on the front of the intercooler! tho now my car over heats if i leave it running to long! your not alone with the problem!
im goin to try an fit the fan between rad and cooler! but got a feel thats goin to be a mission!
Old May 29, 2005 | 04:33 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
your mistake there was fitting the fan on the wrong side of the rad, it should ideally go inbetween the rad and ic or like james infront of the ic, but on most cars this isnt sufficient for cooling.
Old May 29, 2005 | 06:39 PM
james_birch
with the rad tec there is no room between rad and cooler!
is well annoying! unless u move rad back and move cooler forward (bend them brackets to help) then u might just be able to squeeze it in there!
Old May 29, 2005 | 09:34 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
my car has a spal fan between the rad and grs, cools her a treat and is fine n dandy on all but the hottest days when thrashing, some ppl have 2 fans but my 1 is fine
make sure the polarity is right, ive seen ppl with em blowing out rather than in a few times now
what are they thinkin
Old May 30, 2005 | 10:20 AM
Stoo's Avatar
Stoo
My mate fitted a Radtec I/C with 2 fan's.Didnt need to do ANY moving of part's at all,it just all fitted perfectly and plenty of space between the fan's and the back of the I/C
Was well annoying as id spent all day and night fitting my GRS
Old May 30, 2005 | 04:02 PM
vroooom ptssssh
It Wasnt Me!
Stoo, ffs all day and night for a GRS, i fitted one in 4 hrs and it never overheated once lol
Old May 30, 2005 | 04:33 PM
Stoo's Avatar
Stoo
Ha,slow and steady win's the race
Im not a BODGE job kinda guy...
Old May 30, 2005 | 04:40 PM
vroooom ptssssh
It Wasnt Me!
do F1 pit teams bodge there pit stops
Old May 30, 2005 | 05:33 PM
Stoo's Avatar
Stoo
Damb it boy you have an answer for everything!
Old May 30, 2005 | 05:42 PM
james_birch
how deep is your mates rad teck?!
Old May 30, 2005 | 06:04 PM
Stoo's Avatar
Stoo
Here's a pic:
Fitted no problem.2 SPAL fans and never any issues with overheating.Run's very cool
Old May 30, 2005 | 06:21 PM
vroooom ptssssh
It Wasnt Me!
Stoo,
Old May 30, 2005 | 08:57 PM
rs s2 87's Avatar
rs s2 87
Lads...I was so pissed off about my unproductive Saturday, today I decided to buy a double capacity i/c...I'm calling it the sress free one...I needed the car finished this weekend because it is booked in for some spraying....Cheers anyway....front mount i/c RIP hhhmmm what will i do with it...
Old May 30, 2005 | 09:44 PM
vroooom ptssssh
It Wasnt Me!
send it my way
Old May 31, 2005 | 08:21 AM
rst steve's Avatar
rst steve
I had my fan on the front of my Radtek and found the car ran very hot but with a bit of cutting of the front bumper i managed to get the fan in between the rad and the cooler and to be honest their is quite a bit of room could easily fit another one plus the car now runs a lot cooler
Old May 31, 2005 | 12:06 PM
davidnormanuk's Avatar
davidnormanuk
Where's the best place to buy a slimline fan to fit inbetween the intercooler and radiator as I don't fancy cutting my bumper up?
Dave
Old May 31, 2005 | 01:58 PM
vroooom ptssssh
It Wasnt Me!
http://www.kenlowe.co.uk/
http://www.racerpartswholesale.com/fan.htm
maybe somewhere like GRS who sell kenlowes with there IC's may do them cheeper, or try looking for a 2nd hand one.
martinmilne
Oct 18, 2019 02:18 AM
paceo
Feb 3, 2016 10:31 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
cozzy jeff
Aug 14, 2015 05:46 PM
woodz77
Sep 20, 2004 04:45 PM
