Washer pump problem
Old Nov 13, 2014 | 01:07 PM
johnboy73's Avatar
johnboy73
Default Washer pump problem
got a non working washer pump.changed pump,changed switch,checked all wiring but still can't get it working,can anybody help??
Old Nov 13, 2014 | 03:24 PM
studabear's Avatar
studabear
Are you getting a 12v live and a earth at the pump?
Old Nov 13, 2014 | 04:44 PM
johnboy73's Avatar
johnboy73
No,I seem to have two lives!
Old Nov 13, 2014 | 05:00 PM
studabear's Avatar
studabear
Do they have a relay?
Old Nov 13, 2014 | 05:15 PM
johnboy73's Avatar
johnboy73
As far as I know it's the same relay for the intermittent wiper which seems to be fine
Old Nov 13, 2014 | 05:46 PM
martysmartie's Avatar
martysmartie
What do you mean by two lives?
The switch completes the ground.
Martin
Old Nov 13, 2014 | 06:07 PM
johnboy73's Avatar
johnboy73
Just going by what my mechanic was finding,he is at a loss as to what the problem could be,it would seem that when you press the switch both wires to the pump are both live
Old Nov 13, 2014 | 06:55 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
the pump is a 2 way unit, just buy a series 1 or mk3 escort pump , fit it and add an earth
you won`t have a rear washer, but your front will work,
hardly ever need the rear washer anyway
tape the other live up or use the 2 lives in 1, add the earth to the other, sorted !!
Old Nov 13, 2014 | 07:08 PM
johnboy73's Avatar
johnboy73
Cheers for that,it's the one problem I have left after its 18 month restoration!
Old Nov 13, 2014 | 07:23 PM
mk2grp1's Avatar
mk2grp1
it does show an earth not far from the switch, maybe on column or above drivers front speaker area, you could have missed 1 out sometime, have a good look with a torch, otherwise fit the mk3 pump and settle for working front washer, rear isn`t a mot fail
Old Nov 15, 2014 | 07:55 PM
whiskey's Avatar
whiskey
sounds silly but have you put the wipers on when trying? all my mk4s have only worked when wipers put on first
Old Mar 26, 2015 | 02:11 PM
johnboy73's Avatar
johnboy73
Just an update,the problem turned out to be the connector near the washer bottle.all cleaned up and working fine.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Kam B
Sep 24, 2015 10:40 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
