Electrical problem s2
Old Dec 4, 2013 | 07:11 PM
rs_turbo_ant's Avatar
rs_turbo_ant
Default Electrical problem s2
Well last night she just cut dead, there is no ignition lights but i have side lights and fans, all fuses are good but i anit got a clue any help would be great cheers
Old Dec 5, 2013 | 06:48 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Check all the wiring across the front of the engine bay, check earth straps, check under dash steering cowling to see if the ignition switch is turning when key is turnt
Old Dec 5, 2013 | 08:10 PM
martysmartie's Avatar
martysmartie
These have a common problem with a yellow relay, not sure which one, someone with first hand experience can tell you more.
That or you have an immobiliser problem.
What fans are you referring to?
Martin
Old Dec 6, 2013 | 08:48 AM
rs_turbo_ant
Ain't got a immobiliser, just my radiator fans there on a switch, just got to look really just odd that i got side lights still
Old Dec 6, 2013 | 11:06 AM
nykola's Avatar
nykola
Check second stage on the black cap is showing power from it, the side lights don't need the key to be turned to the red dash lights to work, everything else does
Lee
Old Dec 6, 2013 | 12:21 PM
martysmartie
That is not good, I am surprised you even got it insured without one!
Now I know that, check the ignition switch.
Martin
Old Dec 7, 2013 | 01:41 PM
rs_turbo_ant
Ive done it was a melted wire wasnt to hard to find thanks for your help
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
