Electrical problem
Old May 4, 2004 | 10:17 PM
naz121's Avatar
naz121
Default Electrical problem
Hi ther
Ive got a problem with my s2 ther are no ignition lights ,fan not working when hot, headlights not working, also indicators basically everything that works with the ignition being on doesnt seem to work as the car starts up ok just no electrics no dash revs work and no temp gauge moves and also fuel gauge is dead.
Is ther a main relay or fuse that controls all these things.
cheers
Old May 5, 2004 | 01:22 PM
james_birch's Avatar
james_birch
take it to fords!
Old May 8, 2004 | 05:48 PM
Alan s1's Avatar
Alan s1
some of those things are wrong with mine will be working on it thin wk end going to put new builbs in it and new relays as well and fuse is ect
Old May 10, 2004 | 10:06 PM
Alan s1's Avatar
Alan s1
Default Re: Electrical problem
Originally Posted by naz121
Hi ther
cheers
ive got fuel gauge and rev counter and it starts up but got fook all esle so im stuck now
Old Dec 29, 2008 | 11:54 PM
RSTurboNath's Avatar
RSTurboNath
i have a similar problem. no dipped lights, engine fan, indicators or heating!
Old Dec 30, 2008 | 09:48 AM
blueskies85's Avatar
blueskies85
could it be a faulty earth somewhere?
Old Dec 30, 2008 | 12:31 PM
iansoutham's Avatar
iansoutham
OCD Victim
Most likely either an earth missing/dodgy (have you had the battery off recently?). Check the fuse in the fusebox for the brake lights. It goes to the ignition relay in the fusebox as part of its circuit.
Old Dec 30, 2008 | 01:52 PM
RSmark84's Avatar
RSmark84
as just mentioned, the brake light fuse is use for most dash instruments.
Old Dec 30, 2008 | 09:43 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
I had the same problem...change the brake light fuse....
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
