how can I tell a series 2 gearbox from series 1
Hi all. Looking to fit an lsd to my mk5 fiesta. Apparntly I need a series 2 as the lsd has an 8 bolt crown wheel. How do I know an s1 from s2 without opening it? Thanks
I think they both have different mountings . I think a S2 sits on a cradle under the box and a S1 holds the box from the chassis . The s1 has 4 bolts in a square pattern facing to the front of the car and the s2 has 2 gearbox mounts facing the floor underneath the box .
Series 1 on the left , spot the 4 bolt holes in a square . Hope that helps :)
Originally Posted by rustycosworth
(Post 6197816)
Thanks very much lads. Very helpful. Am I right in saying I need a series 2 diff for an ib5 with small machining to the crown wheel? And all series 2 boxes have an 8 bolt crown wheel?
Originally Posted by kgogarty
(Post 6197864)
There's alot of peolpe selling box's as rst box's either because they think people wont know the difference(most dont) or because they hve removed it from there rst and genuinly dont realise its not the original rst box but a replacement as the box's all look the same and codes on the box's are all the same
Originally Posted by doga-ot
(Post 6197860)
Correct also a series 1 didnt have an lsd only a series 2 did and you can tell if its a standard box or series 2 box by lookking in where the drive shafts go
I think the series one had 6 bolts holding it to the crown wheel where as the series 2 had 8 bolts. From what I've read it's the 8 bolt diff you want for fitting in to an ib5 well I hope it is as that's what I've got & want to fit it to lol |
S1 rs turbos came with lsd. Stace
(Post 6197860)
Edit to add, agree with both posts above. Also to add the Fiesta RS Turbo did not have LSD. |
Im not 100% sure all Series 2s had an 8 bolt crownwheel, as ive stripped a couple of series 2 gearboxes now and theyve had 6 bolt crownwheels...?
Originally Posted by RSmark84
(Post 6198335)
Thats incorrect, The Escort RS Turbo was the first front wheel drive road car in the world to use 'this' compact viscous-coupling design limited-slip differential instead of a normal mechanical limited slip differential.
EDIT: sorry not the late series1's it was the top spec series 1's that had it fitted
(Post 6201650)
also my series 2 with zvh kept blowing box's in the end i got a series1 box and had my lsd/crown and final drive put in it (series 1 box) and it had no lsd in it and was off a B reg series 1
every s1 came with a lsd box wes
(Post 6201650)
Yes you will need an 8 bolt LSD which is from a S2 box. I've never found a 6 bolt one in a S2 box but if Roger has then there's a chance you might have to strip a couple to find one, could be that a S1 gear set had been fitted to a S2 casing maybe? Anything could have happened over the last 25 years! :cry: lol |
(Post 6201688)
Originally Posted by slimwynn
(Post 6201643)
i'm sure it was only the s2's that had them.
© 2024 MH Sub I, LLC dba Internet Brands
