wiring issues
Old Feb 10, 2013 | 09:51 PM
fsteward's Avatar
fsteward
Default wiring issues
will a
FORD ESCORT MK4 XR3I CABRIOLET wiring loom fit a s2 escort hard top i know its a long shot but i cant find a xr3i loom for my conversion only one on ebay at £165 and im not willing to pay that cheers guys
Old Feb 10, 2013 | 09:54 PM
studabear's Avatar
studabear
it will fit, but might need a few mods, like rear wiper, rear lights etc
Old Feb 10, 2013 | 11:59 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
I paid like £20 for my efi loom. Pus postage. Try an Orion or ghia loom.
Old Feb 11, 2013 | 12:04 AM
AstoN_B's Avatar
AstoN_B
Why do you need a loom is it for efi conversion? If so you can use a fiesta loom too cause there's only a couple wires to connect on the plug.
Then you can use FRST, xr2i 8v/16v, rs1800 etc.
Old Feb 11, 2013 | 11:43 AM
Karlos G's Avatar
Karlos G
Balls Deep!
As per your other thread, try and avoid using old looms, new management will come with a new loom, you only need to fit the plugs on the end mate.
Old Feb 17, 2013 | 12:30 AM
fsteward's Avatar
fsteward
yea but ive made my mind 100% now and im going for boost monkeys ecu as it direct plug in to a xr3i loom dont want to use a frs loom
Old Feb 17, 2013 | 09:37 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Fair play mate, hope it all goes smoothly! Be worth continuity checking the whole loom before fitting, that way you can repair/replace any broken wires.
Old Feb 17, 2013 | 10:17 AM
AstoN_B's Avatar
AstoN_B
The engine bay loom for the fiesta and efi 3i are essentially the same, there is a yellow plug on most escort looms which has the power for an engine bay loom.
the bay is a standalone loom essentially, it has a couple wires which connect it to the car, like power, earth and rev counter signal etc, from there it does its own thing. But if you use an xr3i loom you'll need to change some pins around to plug in the OFAM. Unless they do it on the ecu when building it.
Therefore you don't specifically need a certain loom, which makes finding one a bit easier. That was my point.
As Karlos says, good idea to do continuity check on the loom anyway, you could also test resistance for the important wires cause they may have degraded giving more resistance which would cause false signal.
Mark_
14
Jan 16, 2016 05:27 PM
cossie brad
Sep 29, 2015 02:38 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
