HELP!!!!!!!
Old Jan 20, 2013 | 07:21 PM
Turbotodger's Avatar
Turbotodger
Default HELP!!!!!!!
Hi all iv dune a head gasket on my car today and now the injectors don't work can any one help
Thanks Shane
Old Jan 20, 2013 | 07:28 PM
cossiejay's Avatar
cossiejay
what car is it
Old Jan 20, 2013 | 07:34 PM
Turbotodger
S2 RST
Old Jan 20, 2013 | 07:54 PM
liam-rst's Avatar
liam-rst
shit happens
Still on mfi? Get someone to pump the flap on the metering unit whilst you turn the car over, mfi is a bastard once air is in the system, also check the obvious like the pump is priming
Old Jan 20, 2013 | 08:35 PM
Turbotodger
Yes its still on mfi and the fuel pump is priming will get someone to push the flap tomorrow and let you no how it went
thanks
Old Jan 20, 2013 | 08:48 PM
liam-rst's Avatar
liam-rst
shit happens
Crack an injector off at the metering unit one by one an check you have pressure in the lines
Old Jan 20, 2013 | 08:53 PM
Turbotodger
I did this with no luck no even a dribble
Old Jan 20, 2013 | 09:02 PM
liam-rst's Avatar
liam-rst
shit happens
Well first things first, work your way from back to front, checking you have fuel going into and coming out of the filter, then check its getting into the metering head, then try pumping the flap, this is how I had to get the fuel up in mine, if not pm me
Old Jan 20, 2013 | 09:44 PM
Turbotodger
I have checked that fuel is at the filter and it is and fuel was at the other end of the pipe on the metering unit when I cracked the nut but I haven't pumped the flap yet will do so in the morning and let you no how I got on
Thanks for the info
Old Jan 20, 2013 | 09:55 PM
liam-rst's Avatar
liam-rst
shit happens
Ok then just the flap to try then mate, I take it the car was running fine until the gasket let go?
Old Jan 20, 2013 | 10:23 PM
Turbotodger
Yh it was fine I only notice the gasket had gone when I checked the water and it was quite low with no signs of a leak so I went to work and dune a head gasket test and it said I needed one so I changed it but if I didn't check the water I would never had known
Old Jan 20, 2013 | 10:36 PM
liam-rst's Avatar
liam-rst
shit happens
Don't sound like it could be a faulty metering unit then, let us know how you get on, good luck mate
Old Jan 21, 2013 | 08:50 AM
Turbotodger
I pumped that silly fu**ing flap and it started on the button thanks for all the advice I have my daily hack back now
Old Jan 21, 2013 | 09:11 AM
liam-rst's Avatar
liam-rst
shit happens
Top man well done mate, pleased to help
