piston broken
Old Apr 25, 2004 | 10:41 PM
Default piston broken
Due to a high boost without the fueling to match my piston nr. 2 has been dammaged.
I've got a spare set of used pistons.
What should i do.
Replace 1 piston or replace all 4 pistons, and would i need new piston rings??
Thanx
http://members.chello.nl/g.giliams/zuiger4.JPG
Old Apr 25, 2004 | 10:43 PM
most of the people round my way are pistonbroke
Old Apr 26, 2004 | 06:46 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
depends wha you expect from the engine mate high power if it was me i would change for uprated items but its not a cheap job but if your ona budget then yeah just cange the pistons might aswell change all the rings while your there!!
Old Apr 26, 2004 | 09:03 AM
Yep on a budget over here
But should i replace all pistons or just the one i can see is broken?
When i save some money there'll come some low comp.
Old Apr 29, 2004 | 11:22 AM
Rick's Avatar
Rick
depends how healty the old pistons are. You can usually get away with it, but u have to make sure they are the same compression height - so get them measured.
Nov 1, 2015 06:53 PM
mjonathan24
Oct 29, 2015 10:39 PM
deathrider666
Sep 28, 2015 06:12 PM
ajamesc
Sep 8, 2015 06:51 PM
