Rs turbo CTS gearbox
Are they any good ?
depends what your expecting
Originally Posted by studabear
(Post 5995711)
reliability |
Depends upon power and your luck lol
Originally Posted by emc-rst
(Post 5995714)
reliability
For the money no they are not worth it... They are essentially just a stock IB5 gearbox (mk5/6 escort, Ka, Focus, etc...) but without the extra case webbing (reduces flex under high torque) fitted with a Quaife LSD and if you pay top dollar a shot peened gear set... Unfortunately this does not stop the shafts snapping :cry:
For the same money you can buy 100 low milage IB5 box's and drop your RST LSD :thumbup: |
I found mine very worth it indeed. The current one lasted very very well. Mine is the lesser box so has the standard LSD that's pumped up a bit. Before this box I'd gone through 12 others.
In terms of B5/IB5's they are without doubt the best gearbox you can buy for an RS Turbo. We only recommend CTS for IB5 boxes, and they are worth every penny!
However fundamentally the IB5 is'nt all that strong, so you have to put things in perspective. Ideally we say they are great up to 250bhp, over that Im affraid its a bit of a lottery, some last at 300bhp, some dont. That in no way reflects a fault on CTS's behalf, simply that the box is'nt really strong enough for 300bhp no matter how you modify it! So the answer is, if you're below 250bhp its a fantastic box. |
Were no good on my s2 which broke a stage 2 box 3 times, got fed up in the end and was just putting recon ib5 boxes in at £80 a go. If you have a big power s2 save your money up for a frs box conversion, then forget about it. Are you zvh or zetec?
£1500 and they don't outlast a stock IB5 which can be picked up for £30 with 36k miles on (picked up a few around this price and milage) it's just not worth it IMO, if you want the Quaife LSD then buy one for £600 and drop it in, still less than half price :king:
Originally Posted by jaiscossie
(Post 5996423)
no mate, I should only be running around 2oobhp on cvh after the build, just wanted a good box to fit while the engine and box is out so that Im only fitting it once, cheers |
Originally Posted by Karlos G
(Post 5996472)
is their much diffrence between the ib5 and turbo box mate |
Bigger bearings, stronger casing (more webbing), self centering neutral, but no LSD.
(Post 5998197)
are all ib5 boxes the same m8 |
IMO there a great gearbox I have the stage 2+ and running 210bhp - 230torque and it loves it!!! Have the BnM shifter also, bang through the gears like no tomorrow, grips in second and pulls like a bastard.
(Post 5998206)
Surely gearboxes are rated in torque and not power?
ginge, he was asking if they were the same not stating that they are
Originally Posted by It's Czech Mate
(Post 5998274)
Shame there customer service is shit and they don't believe in phoning customers back.
(Post 5998274)
well my mark 2 fiesta is 300bhp + 350lbs torque and i got a stg 2 + from cts i track it hard ive done loads of 1/4 miles at pod on track tyres and 0-60s and its been fine which to be fair has shocked me, so to be fair i rate them :top: |
Will the rst LSD fit straight into the ib5?
(Post 5998274)
Originally Posted by Chopshop85
(Post 5998334)
I've always thought this as well. Surely a maximum torque rating would make more sense.
Originally Posted by rs cab
(Post 6003956)
(Post 6004267)
I dont think they are 'rated' to anything as such? But yes torque is what will kill them.
Cheers for that Karlos, think i`ll get myself one of them box`s so.:top:
No worries mate, just a much cheaper option than the CTS with very little difference.
What ib5 boxes fit i presume escort, fiesta, but what else? as mine is whining in 1st gear and clutch starting to slip so going to change gearbox when i do clutch i also still have the crap abs will this make a difference when i have fitted gearbox to refit all the abs bits etc??
Ideal time to lose the abs really.
:thumbup: |
is there any modifications you need to make to the ib5 to fit
is their any modifications to make the ib5 fit or is it a straight swap
Are the ib5 gears any stronger than a s2 box
© 2024 MH Sub I, LLC dba Internet Brands
