indicators
Old Feb 2, 2012 | 02:53 PM
raycov's Avatar
raycov
Default indicators
why have all my indicators stopped working, checked the fuses in the fuse box all ok
Old Feb 2, 2012 | 03:00 PM
Fordmad!'s Avatar
Fordmad!
Check the earth for them.
Old Feb 2, 2012 | 03:44 PM
lewis.philcox's Avatar
lewis.philcox
+1
bad earth can either stop them working full stop or cause it to make other lights flash
Old Feb 2, 2012 | 04:08 PM
raycov's Avatar
raycov
wheres the earth
Old Feb 2, 2012 | 04:09 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
You driving a BMW?
Old Feb 2, 2012 | 04:36 PM
Fordmad!'s Avatar
Fordmad!
If its an s2 rs turbo then behind the passenger headlight.
Make sure the earth has a good contact and that the connector isnt rusted if it is then chop it off and put a new one on!
Old Feb 2, 2012 | 04:45 PM
raycov's Avatar
raycov
it is a s2 i will check it in the morning
cheers
Old Feb 2, 2012 | 06:18 PM
jan247uk's Avatar
jan247uk
SE500 All Blue
just also make sure you havn't caught the hazard warning button or try switching it on then off i have had that switch cause your problem
Old Feb 2, 2012 | 06:22 PM
martysmartie's Avatar
martysmartie
Do you have power to a side with the ignition AND whilst indicating in that direction?
If not then you have a power problem, not a ground issue.
Martin
Old Feb 3, 2012 | 08:25 AM
Danwood79's Avatar
Danwood79
Think there is a relay on the indicator stalk aswell, might worth a check.
Dan
Old Feb 3, 2012 | 01:21 PM
raycov's Avatar
raycov
checked the earth its ok,when i press the hazard warnig light all 4 lights flash ok.i have power to the indicator stalk but there is know power to the indictors
Old Feb 3, 2012 | 06:32 PM
jan247uk's Avatar
jan247uk
SE500 All Blue
have you tried the fuse its fuse 13 in the fuse box (also works the reverse lamps)
Old Feb 4, 2012 | 10:28 AM
raycov's Avatar
raycov
cheers jan that fuse had blown when i checked them brfore i did not notice it as it was very hard to see where it had broke
thanks lads
Old Feb 4, 2012 | 10:44 AM
raycov's Avatar
raycov
just a quickie how would you check the horn if it stopped working when you put a live to the horn terminal from the battery its ok
cheers
Old Feb 4, 2012 | 05:30 PM
jan247uk's Avatar
jan247uk
SE500 All Blue
check for 12v at the terminal and work back from thier has this stopped working since you had the indicator problem?
Old Feb 4, 2012 | 06:02 PM
raycov's Avatar
raycov
no its been like it for 2 weeks or so
steve.rst
Mar 15, 2016 08:01 AM
Rammer46
Sep 18, 2015 08:31 AM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
